AustinAggie
- Dec 16, 2016
- 15
- 5
- New Braunfels, TX
- 2016
- 5.7L HEMI
I just bought a 2016 1500 LoneStar.. new member to the forum and first time poster after being a long-time owner of a Nisan Titan and a member of a forum for that truck. I've been experimenting with which audio formats are supported to find the best audio quality using musc on a USB stick or SDCard
The tl;dr; version of this post: Use WMA Lossless (best audio quality) with a 64 GB SDCard (NTFS) for the most space without slowing music navigation down too much.
More below:
I've been experimenting with the best way to listen high quality audio (ideally lossless but not crazy large file sizes) via SDCard or USB. I've tried out various music formats and SD card sizes and types, so I figured I'd report my results here.
First, some context:
I tried two different types of SD Cards - both worked.
I tried several audio formats. I am not an iTunes/iPhone user so no Apple formats. Surprising results here, don't match the manual.
Anyone else have results to report? What is your format of choice and why? Anyone find one they like better for sound quality?
More below:
- I have UConnect 8.4A, currently up to date on all software updates.
- For comparing sound quality, I'm just using my ears/personal preference. My truck does have the Alpine upgrade, and 192kbs or even 256kbps just didn't exercise the system the way I'd like. Sirius, FM radio, etc all sounded better (except for bluetooth, which was the worst.)
- So, I have a bunch of CDs ripped to FLAC, and was looking for a way to listen to those at very high quality but with an SD card that wasn't so large it brought navigating the music on it to a crawl.
- 32 GB SD card - SanDisk 32GB Ultra Class 10 SDHC. Formatted using FAT32. This worked flawlessly but was a bit small. Navigating music was very fast, even with the card almost full.
- 64 GB Micro SD CArd - SanDisk Ultra 64GB microSDXC UHS-I Card with Adapter. Formatted using NTFS. Despite the manual claiming only 32 GB and hearing elsewhere only FAT32 was uspported, this worked as well. Navigating with the card nearly full of music was a bit slower but was good enough. I was expecting to use WMA Pro since the manual said that was supported.
- MP3 - 256 CBR, also VBR - these all worked great but sound quality was not good neough
- WMA - 256 kps worked just fine, similar sound quality to MP# but used less space
- WMA Pro - VBR - did not work (even though the manual says it will). Track info can be read but track can't be played.
- WMA Pro - CBR - I think 256 kbs - did not work (even though the manual says it will) - Track info can be read but track can't be played.
- WMA Lossless - worked! (even though the manual says it isn't supported) These are large files, but delivered by far the best sound quality (again, at least to my ears on my setup.. YMMV)
- FLAC - as expected, this did not work. would not even find the track info.
