Got my amp and subs
scott2488
Olney, IL
Got my amp and subs, but want to know where everyone runs their power wire to the battery. Drill my own hole or is their someplace better to run it.
Will post pics later, after I get it put in.
quietpeen
2021 TRX
Hellcat
There is a perfect spot where the clutch would be and there is a plastic blank of plate that you can drill trough. Unless your truck is a standard. Can't remember
LB3711
Trumbull, CT
3.6L V6
theres always a grommet to run extra wires thru. I used the one where the clutch pedal would have gone thru
Sent from my tapatalk equipped Transformer TF101
scott2488
scott2488
Olney, IL
Mine is an auto, it must be the black plate next to the steering. Should be easy to do then.
MADDOG
Living in a Firepit
6.4L HEMI
There should be one a bit higher up the firewall on the driver's side that looks a lot like the clutch linkage one. That's the one I used.
scott2488
scott2488
Olney, IL
Got it hooked up today. Slid a grommet over and ran the power wire thru there. Sounds decent!
scott2488
scott2488
Olney, IL
I got a 600 watt xplod amp from a guy from work and a set of 12" fusion subs in boxes
ChloeBrooks
