when i had changed mine out to white, i just took the switch apart and took the old bulb out and soldered in an SMD led. If you go to radio shack and pick out a high power red led and a 440-470 ohm resistor youll be all set. i used 1 led in mine and it lit it up perfect with no hot spots
I can't help. But I'm interested to see if it works. And how it looks.
What do you mean SMD?
