High powered fog lights, 1000watts
sullivan
Houston, Texas
So I was out on a HOS ship this past weekend helping with a Chevron pipe install. Anyways, while on the site, we had several 1000 watt work lights. I got to thinking, these things were very efficient on power, and could be purchased online or possibly at a home depot. These suckers are super bight. They make night time day time, imagine if they were used as behind the grill auxiliary fog lights. They are usually not even shined on the work area, they are pointed at walls which then pretty much bounces off and lights up all over.
Additional batteries would be used, and they wouldn't be turned on for long periods of time.
Its kind of like changing your horn to a train horn haha.
Anyone got some thoughts about this idea?
nim81
Fredericktown, MO
5.7L
i would say just go for hid's. you wont need an extra battery setup and if you really need more light than they put out you should probably be pulling one of these around with you.. and if you did have light like this on your truck you would need an onboard generator to power them.
LB3711
Trumbull, CT
3.6L V6
I hope not on a vehicle that would be crazy. I think the ones they use on rally cars are bright enough. You'd need at least 85 amps if you run them off of your 12 vdc system.
Sent from my AT&T iPhone 4.
sullivan
sullivan
Houston, Texas
Those aren't the lights I am speaking of. Thats overkill
ramhunter9
P-Star Jeep Wrangler
Im running 2 hids and 4 fogs .. I would recommend a dual battery set up . I did this and the lights are now brighter than before .
Ramchowder
