Installing Subs & Fold Flat Floor???
korby05
Delta, PA
5.9 Magnum
Alright I would like to add a sub to my truck using the fox box since I've heard it's a good setup. On their website it says I have to remove the fold flat floor. I'm only putting one sub in since i use the holes under the seat for my towing stuff. My question is is there a setup out there that I can still put a sub in and use the fold flat floor
the codes
Houston, Tx
Magnum 5.2
custom might be your best option
discojables
Phx Az
Bass > fold flat floor
I've been looking and I don't think there is one... for the 4th gen atleast.
You might want a custom setup. DYI project?
MADDOG
Living in a Firepit
6.4L HEMI
Before you go searching too much, measure how much depth you have between the fold flat floor and the cab floor. Then you can figure out how much mounting depth you have.
shostopper17
I have a 2 door 2011 express and i had a custom box done right behind my seat but had to cut that plastic compartment in the back and put my amp underneath my seat look great fits awesome and sounds amazing
