LED Dome and Cargo lights
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
I've searched all over the Internet, and can't find a clear answer. What size resistor do I need to keep my dome lights from flickering. And both sets of lights from dimmly staying on after the truck is off for about 10 minutes.
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
where did you buy the lights? I got mine from Recon and they don't flicker or stay on at all
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Superbrightleds.com. Just ordered replacement festoon bulbs, and cargo lamp/tail light bulbs. Not the whole housing.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
The lights only flicker when the door is open. If that makes any sense at all? They don't always flicker. Just sometimes.
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
yeah I see what your saying when I first put my lights in they flickerd for like 2 seconds and never flickered again. wish I could help more bud
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
I unlocked the truck, and then locked it to get the lights to turn off, and as you can see, the right light is still lightly on. Then, I went into the truck, and showed all the lights flickering. At the end, when I turn on the one light, only the two I didn't turn on were flickering.
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
that's not a problem......That's strobe lights so people know where the party is at... lol j/k not sure man I have never seen that before
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
I wish! Haha. I'm thinking a resistor needs to be added, just have no idea what size, or where to even get them at.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Put in resistors. And they work perfectly now. Will come on when the truck is off, won't flicker, and won't stay dim when the light is turned off.
ssbargher
6.7 cummins
Blackedouthemi I need your help my truck is having the same issues. Can you tell me what resistors to use and how to attach the resistor. Pics would be awesome, I can pm you my email if it would make it easier
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Basically, yes. Except in this case, I didn't literally tie it into the wire. It's pushed up into the blub socket in the same way the bulb is. So that it is running in parallel to the bulb, through the same socket.
ChloeBrooks
