please help, backup cam went haywire!!
hemi1300
Columbus, Ohio
07 dodge ram with kenwood ddx418 double din/advent cube backup camera installed. Been running this setup for over a year now and backup cam has never experienced any problems. Few weeks ago when it was about 20 deg out i went to use the cam and the screen was going crazy flashing/flickering. Powered head unit on/off and worked fine again. Just yesterday the cam completely went out driving home from work in the snow. Screen will flicker randomly and displays "no signal". After leaving the truck sit in the garage last night, it was working normal again this morning but after 2 minutes driving down the street went out again. My troubleshooting-checked my trigger wire at head unit and rear of truck-constant 12v, tried new rca cable from cam to back of head unit-no change, un plugged all connections at rear of truck and plugged back in-no change. Connections didn't look to have moisture in them, would di-electric grease be safe for rca connections just to eliminate the chance of moisture? My wiring seems to check out fine, so starting to think maybe the camera itself is crapping out. Seems if i leave the truck sit in the garage it will slowly flicker the cam picture randomly, then overnight it kicks back on. Cam is only a year or so old and my truck sits in the garage all week (drive a company vehicle) so can't understand how the cam could already be going bad? Any ideas or suggestions???
hemi1300
hemi1300
Columbus, Ohio
weird, so i left all the connections un plugged for the cam towards the rear of the truck for about an hour or so, and ran the torpedo heater to 70 degrees to heat the garage up. Put a bit of di-electric grease on all the connections and plugged them back in, camera works like normal again. Went for a quick drive and no problems now. So my only thought is a bit of moisture got into one of the connections?? Hopefully the di-electric grease will prevent this from happening again. Any thoughts??
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Sounds like it just got wet like you was thinking.
Meathook
Eastern Kentucky
4.7 Flex Fuel
You might have water in the camera itself. The water might be freezing and messing with the lens.
Ocelot
5.7 Non-Etorque
I wouldn't be surprised if it was moisture in there. Especially salty moisture from road salt. On my old truck when it got cold and wet from road salt my trailer brake control would display that a trailer was hooked up when it wasn't.
