Radio help, maybe just a new one
MoparSickness77
My oem radio works fine except the AUX jack port does not work. When I plug my iPod into it sound only plays on the right side of the truck. CD's and the Radio play perfect so I know its not anything else. Also I turned the dial to make the sound only play on the left side and it plays very very quietly.
Has anyone else had a problem like this? Any ideas on how to fix it?
Or I want to new head unit with the option to watch movies, have reverse camera, and maybe navigation. But I would have to look more into what is out there.
TexasRammer
College Station, TX
could be the aux port on the radio or just the aux cable itself, Ive had that happen a couple times
MADDOG
Living in a Firepit
6.4L HEMI
Try a new cable. I assume there's no problem hearing both sides using headphones?
98sporttj
west chester Ohio
2006 QCSB 4X4
4.7L
does the i pod do that with headphones too? i had this problem with my old ipod and it was the headphone jack... also try a different cable... if nothing else i have a stock raido you can buy
can even toss in the sirius tuner with it too if u didnt have that
MoparSickness77
MoparSickness77
I've tried cables and headphones work fine. I just didn't know if the aux jack is repairable.
This is my second oem head unit (first one had a broken cd stuck inside) so I think I'll just look into a aftermarket one that can do more.
TexasRammer
College Station, TX
could be just a wire lose on the jack, but youd have to take it all apart and re solder the connection if thats the issue.
