Remote start
sullivan
Houston, Texas
Help me hook the rest of my viper up, I have had the alarm portion setup for months, but not the remote start. I have the Viper 5901 and a CHALL setup.
I have a relay ready to hook up for the remote start portion. If I could get some help on what wires I tap into for the R/S system.
sullivan
sullivan
Houston, Texas
Argg. I really dont want to see if best buy can hook up my last few wires...
HemiBabe
DFW
Sowwy... I wish I could help!
jhemi
wisconsin
will this help?
2006 Dodge Ram 1500 Remote Starter Wiring Instructions
Vehicle Battery Positive Wire (+): Light Blue/Red (Low current. For high current application go directly to the battery.)
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Pink/White
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): Pink/Green (There may not be an second ignition wire.)
Vehicle Second Ignition Wire Location: Ignition Switch Harness
Vehicle Accessory Wire (+): Violet/Brown (Use 610 ohm resistor for accessory, same wire as starter2.)
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): Pink/Yellow (This wire will turn on the abs light if not powered up for remote start.)
Vehicle Second Accessory Wire Location: Ignition Switch Harness
Automobile Engine Starter Wire (+): Dark Green/Yellow (Not for remote start, use starter2.)
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): Violet/Brown (Use 180 ohm resistor for starter2, same wire as accessory.)
Automobile Second Engine Starter Wire Location: Ignition Switch Harness
Factory Anti-Theft System: Daimler Sentry Key Vehicle Immobilizer
Factory Anti-Theft System Type: Key Sends a RF Signal to the BCM Module Through an Antenna Located Around the Ignition Cylinder
Crankshaft Sensor Wire: N/A
Crankshaft Sensor Wire Location: N/A
Camshaft Sensor Wire: N/A
Camshaft Sensor Wire Location: N/A
Car Key Sense Wire (-): Violet/Brown (Use an 8.5k ohm resistor for key sense, same wire as starter 2 and accessory.)
Car Key Sense Wire Location: Ignition Switch Harness
Car Neutral Safety Wire (+): N/A
Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): Tan/Red
Car Tachometer Wire Location: At Ignition Coil (On diesel models, the tach wire is at the ECM module on the lower driver side of the engine, pin #24 in front 60-pin plug or at the camshaft position sensor located at the left of the ECM at the 3 pin plug. On SRT-10 models, the tach wire is on the black plug – pin 18.)
Car Speed Sense Wire: Green/Yellow
Car Speed Sense Wire Location: Pin #13 in Black Plug at PCM Module (For SRT-10 models, pin 27 in white plug or dark blue/orange wire. In diesel models, pin 11 at the PCM module.)
Car Parking Lights Wire (-): White/Green (Parking lights are negative trigger thru a 1130 or 250 ohm resistor. Must use a relay.)
Car Parking Lights Wire Location: At Vehicle Light Switch
Car Brake Lights Wire (+): White/Tan
Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): White/Light Green
Car Reverse Lights Wire Location: In Harness at Reverse Light
Car Horn Wire (-): Green/Violet
Car Horn Wire Location: In Harness at Steering Column
Car Rear Defrost Wire: N/A
Car Rear Defrost Wire Location: N/A
The 2006 Dodge Ram 1500 remote start wire color and location information above is updated as it is submitted by the Modified Life community.
sullivan
sullivan
Houston, Texas
That does help, but Ive already got that info. I just cant figure it out myself. The remote start portion is finicky.
jhemi
wisconsin
what exact part of it all dont you understand and ill try to explain it better there directions do suck, and labor costs is crazy
sullivan
sullivan
Houston, Texas
Ill scan the document, and draw some stuff on it later today showing the sections im having trouble with.
jhemi
wisconsin
alrighty that would help me explain alot better
jhemi
wisconsin
do you have the chth2 cord for the chall unit if not get it will make the install way easier, and faster
sullivan
sullivan
Houston, Texas
Yes I have the CHTH2 as well, sorry for not including that earlier.
ruckus
hemi
Help I'm in the process of installing one in my 08, I don't get what has to be wired from alarm to the chall
sullivan
sullivan
Houston, Texas
I highlighted in a light red what I am confused about, I see wires running to different places and I have no Idea where they go. Such as (+)Ignition 2, (-)While Running, Starter(+)
shanmccarthy
