yatzee
- Mar 6, 2016
- 4
- 0
- Canada
- 2003 3500 SRW 6 spd
- ISB305
Hi guys, 1st post - just got my truck a couple weeks ago
Bought the truck with a dead radio. The seller told me that he thought the radio was blown because it stopped working after he'd tried a programmer. When I it to my diesel guy to get the injectors done, he had to repair the OBD plug as it was broken and he wasn't able to communicate to the PCM. He was able to partially repair it - enough to erase the faults after doing the injector job. He had to order a couple pins - I have to go back at some point.
I bought 2 radio adapter harnesses - 1 for the truck side, 1 for the pioneer head unit that I was installing. Did the connections, tested it with a multi-meter, and this morning, installed the radio into the truck. Unfortunately, nothing worked (exactly like the factory head unit)
Checked power (ok from the ignition switch, but not on the 2 pink wires - got .178v), checked grounds (strange readings on these) and basically got nowhere.
I also tested the 12v outlet beside the radio and it was also putting out .178v. Tested the lower 1 and it gave 12v, so I ran the 12v to the back of the aftermarket radio and I still have nothing. I have also checked fuse 51 - it's ok.
My only other clue is strange ignition switch behavior - I sometimes have no interior lights, sometimes the remote doesn't work - seems that there is no power, but this is intermittent.
Where I am going wrong? In my VW and MB world, I would have solved this already!
