WTF is up with my window switch
02Steve15
Connecticut
I just replaced the switch and it still doesn't work. what the **** is going on with this POS?
LB3711
Trumbull, CT
3.6L V6
im thinking the same. Got a multimeter?
02Steve15
02Steve15
Connecticut
the motor is good, i can still move the window up or down from the driver's side
bigtigga84
dela....where?
Is there a relay between the switch and the motor on the passenger side?
bigtigga84
dela....where?
That would be my next guess if the fuses are good. Can you hook the switch to the drivers side and see if it works? I dunno if it will plug up or not, just thrown ideas out to ya.
02Steve15
02Steve15
Connecticut
nah the switches on the driver's side are different sizes so i can't swap them
bigtigga84
dela....where?
Didn't know if the plugs were the same to try it. I was sitting in mime when I sent that earlier too.... looked down and was like, duh double switch.... blond moment for the day
1AJeremyD
Mass
Try doing a resistance check. maybe the wire got cut and is grounding out.
HemiBabe
DFW
Is there a fuse for the windows? Check that if so...
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
its a known problem with the 02 and 03. the problem is actually with the drivers side switch. the wires work themselves loose somehow even though they're still connected. they act like theres a short in the wire, but theres not. some people have had luck with replacing it with an 04+ switch, others havent. dont think there is a definite fix for it, but you're not alone in having the issue....and its not a fuse or relay or anything like that.
THEBAD1
2003 Sport SLT QC2WD
03 here.... I have the same problem and I have replaced all the switchs?
ChloeBrooks
