Check Fault Codes
2010TRX4
I have a 2010 Ram with a 5.7 Hemi. Today The check engine light came on and the MDS won't engage. I was wondering if there was a way to check the fault codes like there is in older models by cycling the key.
Thanks
bigbadram1500
Springfield, IL
hmm I'm not sure since I don't have a 4th gen, but will bump for our 4th genners to chime in.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Should be the same key trick, turn the key from off to on like 3 times I believe?
2010TRX4
Yes, 5/20. I tried cycling the key 3 times earlier today. I will try again in the morning.
Thanks
2010TRX4
Tried it again, but couldn't get it to work. I tried it at different speeds but nothing happened. If it does work on the 4th gen, what's the trick?
LB3711
Trumbull, CT
3.6L V6
ill have to try mine tomorrow and see if it works but I think it does. Dont go to start position. Just on-off-on-off-on and it should work
Herefishy
