Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Tech Info
Sponsored Ads
Register to remove these ads.
Tech Info
- Star Case - 4th Gen Torque Converter Moan, Drone, Rattle Issues
This is a discussion on - Star Case - 4th Gen Torque Converter Moan, Drone, Rattle Issues within the Tech Info forums, part of the 4th Gen : 2009 - Present category!
Register to remove these ads. It's free! Originally Posted by LustinJam Well I got it. LOVE IT. The interior is ...
View Poll Results: Torque Converter - Vibrations Moans Rattles
Have this issue 14 56.00%
Dont have this issue 7 28.00%
Noticed this issue but not worried about it 2 8.00%
Have you had the torque converter replaced 6 24.00%
Multiple Choice Poll. Voters: 25. You may not vote on this poll
Reply
Old 02-05-2012, 02:34 AM   #41 (permalink)
LU229's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
Originally Posted by LustinJam View Post
Well I got it. LOVE IT. The interior is prob one of the best I've come across and although I've always liked the look of my friends' GMCs I wanted something different. This truck had everything I was looking for in it's looks and again, the interior is just amazingly functional.
Well this site has another member! Cheers
Congrats on the new truck, it will serve you well...!!!
Dont worry about the small things with the new truck, just enjoy it.
Change the engine oil ASAP to valvoline synthetic and use the factory oil filters.
LU229 is offline   Reply With Quote
Old 02-06-2012, 07:51 PM   #42 (permalink)
Ram Year: 2011
Engine: HEMI
Default
Thanks, so far so GREAT!
Good info, I was planning on going synthetic but wasn't sure which exactly to pick up. Is there a standard/recommended weight? I live down South in Texas with plenty of heat... Pick up the factory filters from the dealer?
LustinJam is offline   Reply With Quote
Old 02-06-2012, 11:21 PM   #43 (permalink)
LU229's Avatar
Ram Year: 2010
Engine: Hemi 5.7
Default
All my hemi vehicles have done excellent with valvoline "synpower" synthetic oils.
(no worries with texas heat with valvoline synthetic synpower oil, its EXCELLENT shit...!)
Dont even bother with mobil 1, i`ve had issues with EVERY hemi vehicle i`ve used it in.
(with mobil 1, you`ll eventually hear lifters ticking, and have blue smoke out the tailpipes)
With this truck you have now, do NOT run anything but 5w20 in it or the MDS system wont work properly.
If you have a WALMART store near by, they sell the MOPAR oil filters for $5 bucks.
I believe the MOPAR part number is MO899, but look it up to be sure.
They also sell the valvoline synpower synthetic oil as well. (you`ll need 7qts)
The 09 on up hemi`s are different than the 08 on back when it comes to oil filters. Make sure you get the correct oil filter.(thats an absolute must...!!!) If you do your own oil changes, make sure when you spin the old oil filter off that the old o-ring seal comes off with the old oil filter. Sometimes they can stick to the engine block and if not noticed, you`ll have a huge oil leak and possibly seize up the engine if you dont catch it in time. Another trick to changing the oil in these trucks, grab yourself a plastic shopping bag, once you break the oil filter free, slip the bag over the oil filter and spin it right off.(that saves you alot of mess) Fill your new filter with oil before you spin it back on. Grip the filter good, tighten with a good amount of hand pressure to seat it good. When it comes time to re-install the drain plug, clean it off with some brake-clean, spin it back in until finger tight, grab your torque wrench and set it to 25ftlbs, and no more. Once the TW clicks, you`re done. Last but NOT least, dump all 7qts of valvoline in, start the truck, check for leaks, then jump in an drive it like you stole it.
Just some good advice bro, change that rear differential lube ASAP...!
Here again, use valvoline FULL SYNTHETIC 75/140 weight (you`ll need 3 qts of it to do the job)
Dump it in until its just about ready to over flow out of the "Rubber Fill Plug" hole on the rear cover.
If you have a 4x4, the front differential take`s 75/90 weight.
Good time to check your transmission oil level while your under the hood. (dipstick will tell you how its checked)
I`m not a valvoline rep or salesman or anything of the sort, i`ve just had the BEST luck with their products.
Happy hemi-ing my texas brother...!
Old 02-07-2012, 08:46 AM   #44 (permalink)
Ram Year: 2011
Engine: HEMI
Default
Will do!
Thanks again man.
Old 02-11-2012, 08:43 PM   #45 (permalink)
badfish888's Avatar
Ram Year: 2012 hemi express
Engine: 5.7L Hemi
Default
sooooo question before i go to the dealer wed...................is this... Star Case:S1121000005 an actual recal? what does that number mean? can my dealer look it up. cause i called today(i diddnt have that number) and they have no idea of any torque conveter issues, or the cats falling apart that i read on another forum.
just looking for any imput before i go into the dealer and tell them to rip apart my new truck
__________________
MODS-i pulled off the dealer sticker.....
badfish888 is offline   Reply With Quote
Old 02-12-2012, 05:42 PM   #46 (permalink)
badfish888's Avatar
Engine: 5.7L Hemi
Default
bump
__________________
Old 02-15-2012, 09:43 PM   #47 (permalink)
Ram Year: 2011
Engine: Hemi 5.7
Default Torque converter groan
I just had my torque converter replaced under warranty for this problem. The truck has 6000 miles and I started noticing this problem around 1000 miles and it got progressively louder. It took the dealer 2 days to finally isolate the noise. I initially thought it was a harmonic vibration from the exhaust and tolerated it until it started getting louder. My truck was the first one the dealer had ever checked with this problem. Hope this helps. 2011 Ram 1500 ST quad cab 4X4 Hemi 5.7 3:92 axle ABQ New Mexico
roadkingken is offline   Reply With Quote
Old 03-24-2012, 03:12 PM   #48 (permalink)
badfish888's Avatar
Engine: 5.7L Hemi
Default
has any one had this problem on a 2012 yet??
__________________
Old 04-11-2012, 08:14 AM   #49 (permalink)
Ram Year: 2012
Engine: 5.7
Default
Just got my 2012 dc 4x4 5.7 sport Saturday. I have 167 miles on it no issues like stated above. Only thing I'm concerned about but was told is normal is standing next to it while running it seems a little loud. Engine noise wise.
2serious is offline   Reply With Quote
Old 04-11-2012, 08:16 AM   #50 (permalink)
quietpeen's Avatar
4th Gen / Site Mod
Ram Year: 2011 1500 Sport Quad Cab 4x4
Engine: Hemi 5.7
Send a message via AIM to quietpeen Send a message via Yahoo to quietpeen
Default
Welcome to RF!!!
If you start hearing a tick that is normal too. I'm being serious....the hemi's are known to tick........sucks but they do.
__________________
RamForum.com Moderator
quietpeen is online now   Reply With Quote
Reply
Bookmarks
Tags
gas pedal vibaration, star case: s1121000005, torque converter droan
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
DIY: Torque Converter Install OlDirtyJohn 3rd Gen DIY 18 03-22-2012 09:09 AM
Torque converter help moodygunner Engine & Performance 28 11-06-2011 11:43 AM
Torque Converter smiley3303 Engine & Performance 4 09-23-2011 01:15 PM
torque converter might be a no go :( RubberFrog Engine & Performance 90 07-25-2010 08:49 AM
Torque Converter is Here RubberFrog Engine & Performance 17 07-04-2010 08:37 AM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
