Tranny temp
Red 2012 Crew
Central Illinois
Anyone know if you can add a tranny temp gauge to a 2012 express? I would like to be able to watch it towing my camper.
LB3711
Trumbull, CT
3.6L V6
you don't have the EVIC? I can see my temps on that.
quietpeen
2021 TRX
Hellcat
yea if you have the evic it is in there. Trans temp, oil temp, coolant temp
quietpeen
2021 TRX
Hellcat
oh i should have read your whole post and saw that you have an express. I would think you can add a temp gauge, others that know should chime in
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Should just have to drop the pan and have a temp sensor in the pan and run the wire up to a gauge of your choice
Red 2012 Crew
Red 2012 Crew
Central Illinois
I don't think it was even an option on an express. If I put a sensor in the pan how can I route the wire out of the tranny itself? I wonder if there is a way to sense it in the line headed up to the cooler?
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Well drill out a hole in your pan where you want the sensor, have a nut welded in around the whole and screw your sensor into the pan. The wire connects to the sensor and the sensor will just screw in
Red 2012 Crew
Red 2012 Crew
Central Illinois
I found a kit on summit racing that went in line before the cooler. Might give that a try.
S2kiHemi
Houston TX
There used to be a diy on here for how to install one in a 3rd gen. There are some test ports on the right side of the transmission that you unscrew and then screw in a temp sensor in its place. Then simply run your wires to a gauge in the cab and mount the gauge somewhere.
garner
Harker Heights, TX
You can get evic on the express. There's certain options you have to get though that will add it. Think one of them is trailer brake controller
Mad Cow
Anchorage, AK
Cummins 6.7
You could do a door pillar set up and set one guage to the tranny temp. It would look sexy also.
Red 2012 Crew
Red 2012 Crew
Central Illinois
I looked for pillar gauges and can't seem to find and for 4th gens, just 3rds. Anyone know where I could find one for my '12?
matt12328726059
hemi 5.7L
does anyone kno if there is a tranny temp test port on a 11 dodge ram 1500 its self on the trans..i wanna install the trans temp gauge so its eye view but i cant seem to find the test port.can anyone help me with this>>>pics would be nice to if they have info on it
garner
Harker Heights, TX
Is that truck in your profile picture yours? If so sports have trans temp from the factory in the evic
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Then you could just buy a pillar gauge and use that to read it.
TMFMK
