usaf2006
- Mar 28, 2014
- 4,518
- 1,574
- Augusta, GA
- 2008
- Hemi 5.7
I'll be replacing my front struts soon, but that requires removal of the following unless you cab tell me otherwise:
Caliper (not necessary if careful)
Upper Ball Joint
Tie rod end
Swaybar end link
Strut assembly
I can't find torque specs on these items except for the strut assembly which the top nuts torque to 45ftlbs and the bottom bolt to 155 ftlbs. Can someone help me with the rest? I've googled but must not be searching the right thing.
Thanks in advance!
Also, do I need an alignment afterwards if I stay with OEM size struts?
Upper Ball Joint
Tie rod end
Swaybar end link
Strut assembly
Thanks in advance!
