PdPuNOme
02 1500 4.7 4x4 here. Build sheet only states 205mm HD front axle, no ratios other than 3.92 for the rear, so first question is the front the same ratio? Second question on these axles can the left and right seals where the cv goes in be replaced from the outside? Third and final, anyone know another name for this axle and if a gasket is available for the diff cover? I like the gaskets better than the rtv just my personal preference.
Build Sheet Cut:
DJMS 205MM HD Front Axle
DMHP 3.92 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DSAP Anti-Spin Differential Rear Axle
Build Sheet Cut:
