NEED HELP! Won't start!
Royse0121
5.9l v8
My 2002 5.9 won't start!
Drove fine the day before the. The next morning I woke up and it cranks but won't turn over.
I can't hear the fuel pump and none of my gauges or stereo is working. I get the flashing lamp out signal as well as ABS fuel light and park brake. I just replaced the crank sensor and still nothing. Changed the battery and cleaned all grounds. I don't know what else to do. My obd reader says no link also
Rlaf75
East Hartford CT
You can try beating on the tank while someone else turns the key. If you hear the pump run or it starts then you'll need a fuel pump. That's the very old fashioned way but it can still work
