Truck not starting!
sampson19
First time poster, long time reader!
So my 2008 1500 SLT 4X4 decided it didn't want to start this weekend. Locks or nothing worked, but gauges were working, as was the fuel pump. No catch at all, like a dead ignition system. After trying everything I could think of, I was forced to have it towed to the dealer. The tech got the truck running after about 1.5 hours by resetting the remote key module next to the ignition key, in the column. He told me it would go out again, so I said order the replacement and I would put it in myself when it gets in. (still don't have any word when I'll get that)
Next day I was driving my dodge roullette and the check engine light came on, then after about 50 miles, it went off. I thought maybe the battery is dieing. So pulled into an auto parts store. We tested the battery and it was going bad. CCA were real low. Bought a new batter, starting like a champ now.
My question is...I think the low charged, dieing battery may have caused a problem with the remote module, which engaged the anti-theft system, causing the truck to not recognize the key and not turn over.
I think paying for a new module shouldn't be necessary. Thoughts?
Trupiano
Registered User
6.7L CTD
Welcome to RF! Moved this thread to the tech section for ya.
Have them test the battery and see if the one in your truck is just low. Like you said, no sence changing a part for working properly if something else is the problem.
S
sampson19
it was low, replaced it yesterday. I'm thinking i'm not replacing the module now. Thanks for the input, appreciate it.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Would have thought the dealer would have ruled out the battery, that said its easy for a tec to miss something simple.
ChloeBrooks
