Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
Sponsored Ads
Register to remove these ads.
General Discussion
axle/gear questions
This is a discussion on axle/gear questions within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! if my front and rear gears were not matches up in my 97 ...
Reply
Old 02-05-2012, 10:13 PM   #1 (permalink)
tsg2009's Avatar
Ram Year: 1997
Engine: 5.9 magnum
Default axle/gear questions
if my front and rear gears were not matches up in my 97 ram what would be some of the signs and symptoms? i think my gears are 3.55's and im thinking about 3.90s but im not sure if my rear is 9.25 or 8.25 how do i tell?
__________________
tsg2009 is offline   Reply With Quote
Old 02-05-2012, 10:32 PM   #2 (permalink)
iSlacker816's Avatar
Ram Year: 2001
Engine: 5.9 (360ci) Magnum
Default
What do you mean matched up? like a different ratio in the front to rear or vise versa?
__________________
2001 5.9 Magnum 195,xxx Miles - 32" Hankook Dynapro ATM's - Glasspack - Dash Cap - Tinted Tail and 3rd Brake Light - Spectre CAI - HBS 2" Level - HBS Steering Stabilizer - Superchips Flaspaq 3865 - Husky Molded Floormats - Hughes Engine's Plenum Kit - 8 Pass Transmission Cooler - 4 Off Road Lights Behind The Grill w/ Custom Made Light Bar
iSlacker816 is offline   Reply With Quote
Old 02-05-2012, 10:45 PM   #3 (permalink)
Stangshcky12's Avatar
Ram Year: 2005
Engine: 5.9 Cummins
Default
If your truck is 4x4 your gears have to match or your gonna have big problems
The other number you listed is the size of the rearend, you can have different axle sizes front and back
__________________
2005 Ram 2500 5.9 Cummins 6 speed
More Here
I blame spelling mistakes on my phone and I'm sticking to it!
Stangshcky12 is online now   Reply With Quote
Old 02-05-2012, 10:56 PM   #4 (permalink)
MikesRammin's Avatar
Ram Year: 1994
Engine: 5.2 Magnum
Default
The only time that should be considered is in a truck pulling application. "Staggering" the gears helps get more power to the higher traction wheels but with the loose dirt on a pulling track it compsates for the difference. Now in a reg. 4x4 never ever do that. symptoms would be skipping or skidding on the tires. Also jerkyness and I don't know if this would be one but I would think you would hear a whine in the transfer case from the different outputs causing stress.
__________________
1994 Dodge Ram 1500
5.2L 318, TB mod, true duals straights, EGR Delete
Loud and proud baby!
MikesRammin is offline   Reply With Quote
Old 02-06-2012, 11:08 AM   #5 (permalink)
tsg2009's Avatar
Ram Year: 1997
Engine: 5.9 magnum
Default
Ok, I was thinking my front and rear gears don't match, I know the rear axle was swapped before I got the truck, I was thinking about taking the gears out and going taller 4.11's max but I don't know which rear axle I have so I was trying to figure out which housing I have and see what the symptoms would be if the gears were different
__________________
Reply
Bookmarks
Tags
3:55 gearing, 4:10 rear end, axle differences ram, gear swap 2nd gen
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need Axle U bolts mikehutch Lowered 7 01-21-2012 11:56 AM
axle swap questions Badger Lifted 20 01-08-2012 12:53 PM
Axle Swap Gebauer Lifted 17 10-16-2011 09:14 PM
gear install this sunday. few questions pavester Engine & Performance 11 06-07-2011 11:14 PM
Axle Seals RAM_007 Tech Info 13 04-05-2011 03:06 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
