Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > General Discussion
General Discussion
Front differential leak
This is a discussion on Front differential leak within the General Discussion forums, part of the 2nd Gen : 1994 - 2002 category!
There is some sort of device on my front differential that is leaking. It is on the passenger side and ...
Reply
Old 07-14-2017, 11:28 AM   #1 (permalink)
Willmunny's Avatar
Ram Year: 2001
Engine: 5.9
Default Front differential leak
There is some sort of device on my front differential that is leaking. It is on the passenger side and has a couple of hydraulic lines attached to it.
The truck is a 2001 5.9l , slt. The 4wd seems to work correctly. I did not see anything in these forums when I looked. Thanks for any feedback
Sponsored Ad
Register to remove this ad.
Willmunny is offline   Reply With Quote
Old 07-14-2017, 11:48 AM   #2 (permalink)
Willmunny's Avatar
Ram Year: 2001
Engine: 5.9
Default
4wd actuator, I think I found it lol
__________________
2001 Dodge 1500 4wd 5.9 slt
Old 07-14-2017, 05:00 PM   #3 (permalink)
Yeret's Avatar
Location: Under the hood, trying to find that ****ing bolt/nut/socket/wrench that I dropped...
Ram Year: 1999
Engine: 5.9 Magnum
Default
Is it even possible for the actuator to leak? I've honestly never heard of that happening.
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
The only true screw-up is one that can't be reversed!
American Racing Nitro, 265/75/16 Duratrac 10-ply, modified 50mm, eBay shorties, 2.25" y-pipe, Magnaflow cat, Cherry Bomb Extreme, DUI LiveWires/cap/rotor, canned 91 tune by Flyin' Ryan, Hughes plenum repair, 4x4 Posi-Lok
Yeret is offline   Reply With Quote
Old 07-15-2017, 02:43 PM   #4 (permalink)
Willmunny's Avatar
Ram Year: 2001
Engine: 5.9
Default
Here is a photo, it smell like gear oil not motor oil
Old 07-15-2017, 08:36 PM   #5 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
Have you checked the fluid level in your front diff? Pull off the plug and stick your pinky finger in there and set the first joint from the tip onto the bottom of the plug area and turn it down. If the tip of your pinky touches the oil, your level is fine. If it doesn't reach it, add oil little at a time until it does.
Or, if you don't care to be that precise, just add oil until it just starts to spill over the fill hole. This is considered "over filled" for our axles but it's debatable if it will cause any real problem. If you're unlucky, oil will leak past the seals and create a little mess.
__________________
Old 07-16-2017, 11:26 PM   #6 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Yes it can leak. It's a metal-cored cork gasket. TBH, I made my own gasket and didn't have any issues but I would suggest new to somebody else. Problem is you can't buy it new. Have to get it as a piece of some other kit. Summit I believe has a kit that eliminates the actuation part of the actuator for like $30. Easy way to make your 4x4 easier to maintain and get the gasket. Or get it for the gasket and keep the other parts around for later if you're unsure about it
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, CarvenTR, M1 91 Octane canned tune by FlyinRyan, 4.56 gears+Eaton TrueTrack remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 07-17-2017, 03:09 AM   #7 (permalink)
Willmunny's Avatar
Ram Year: 2001
Engine: 5.9
Default
Thanks for the information guys!
Old 07-17-2017, 05:30 PM   #8 (permalink)
BBartow's Avatar
Ram Year: 1995
Engine: 5.9L Magnum
Default
You can buy just the gasket but I used rtv.
__________________
BBartow is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
welded front differential poweredbyhemi Engine & Performance 4 10-20-2015 10:03 PM
Rear Differential Leak RamForLife Tech Info 11 08-18-2014 08:22 AM
front differential problems haroldsworld66 General Discussion 1 01-02-2013 07:41 PM
front differential ? jhemi Tech Info 7 04-19-2012 03:41 PM
Front Differential with pix!! rocket General Discussions 25 08-22-2010 10:10 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
