Puckett1414
- Mar 11, 2016
- 1
- 0
- 1998
- 5.9L V8
Ok guys I'm new to this site and want to thank each of you for any help you may be able to provide. I'll start by saying I am not a certified mechanic but i am self taught and know my way around dodge trucks fairly well, so here are my symptoms and issue at hand.
So the truck has been sitting for a while, but its been sitting because it became a secondary vehicle and quit running one day when i went to start it. I had noticed when i was driving it that it would randomly give a low power surge occassionally while driving down the road. Here's what I mean by low power surge, no matter how fast I was going or if I had my foot on the gas or if I was coasting, It would never stall but for a brief second it would dim the lights and drop about 100-200 RPM's but only for a second then it was fine. It did this long enough for me to think it was normal behavior for my truck.
So when it wouldn't start, i narrowed it down to getting no fuel and all the fuses and relays i could find related to the fuel pump checked out and switching relays for ones i knew worked provided no solution. So i assumed the pump was bad, dropped the tank and installed a new pump, reinstalled and still nothing. So i checked voltage with the key turned on at all prongs for the ASD (Automatic Shut Down) relay and fuel pump relay and on one prong for both i get slight voltage (up to 1 volt) for less than 2 seconds and it drops to 0.000 on the multimeter. I have charged and tested the battery so unfortunately keeping it simple also did not provide a solution.
Im led to believe i should have close to 12 Volts with the key turned on at least at 1 of the prongs for each relay. Im at a loss at where to go to next, and how to test my PCM. The truck has 155, *** miles. Any help is greatly appreciated and please let me know what more information i can provide for an accurate solution in troubleshooting. I dont believe a bad crankshaft or camshaft position sensor would kill the power to the relays because i have zero volts prior to the cranking procedure. The truck does tuen over at a normal RPM and sounds normal turning over. Thanks in advance for the help and suggestions!
