More bullsh*t, it just keeps coming
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
So today being my day off I changed my oil. Being 30 degrees, I wasn't very happy about crawling under my truck in the driveway. I really wasn't happy when only a couple quarts came out :/. WTF to do now? I guess I'll check the TB for oil to see if the plenum is leaking If not I don't know what the hell else to do...
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
only a couple quarts came out? You keeping an eye on your oil level?
S2kiHemi
Houston TX
Yea only a couple quarts coming out isn't good.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Sounds like a case of plenum leak. I had the same thing. Scared me to death. But trucks fine. Fix the plenum and you will be good.
iSlacker816
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
Update: TONY WAS RIGHT!!! lol pulled my CAI off today to look and sure enough looks like slight oil build up in the upper intake. Guess I'll be ordering a a plenum kit here soon!
MADDOG
Living in a Firepit
6.4L HEMI
How do the plugs look?
the codes
Houston, Tx
Magnum 5.2
plugs could tell you had bad it was. my plenum had been blown a while and kept fowling my #8 plug in a matter of weeks. I finally researched it and found out what the plenum problem was.
Tapatalk Addict
V-10 RAM
Lee Vining CA
v-10
I posted a TSB on oil in plenum & how to check it for sure. My Jeep 5.9 Limited had oil residue in the plenum & it turned out to be a PCV valve. I believe the TBS is in the DIY section or Tech section. I'm not saying it isn't the plenum gasket but Dodge has a test to check it & be sure. The test is easy.
TMFMK
