01-08-2012, 10:00 AM
#5 (permalink)
Ram Year: 2000
Engine: magnum, 5.9
You'll really need the front springs from a cummins equipped Ram to get the desired 3 inches of lift.
There are a couple down sides to this mod. First, Cummins springs are very stiff. They were designed for holding up a front end with a much heavier engine. Combine this with the increased angles of your control arms and the ride becomes bone jarring. Sure it's a truck..but now it's a tank. Handling on rough surfaces becomes a bit skittish.
The second part is that you will also uncenter your axle in you wheel well about an inch and also uncenter your axle between the frame the same amount. Again this is due to the triangulation of the links and track bar.You can reset the toe and caster, but you will increase bumpsteer. The tire clearence you think you'll get may not be there. BTW, you'll max your caster adjustment on your factory arms. There was an earlier post about "Death wobble" in this section. Improperly done lifts increase wear on important components, and when combined with poor ride and handling can be deadly.
I'd rather see you put an AAL in the back than stack blocks. I'm sure I'll be flamed for this, but stacking blocks...is stupid.
__________________
Life is a Highway...I wanna drive it all night long...
