blindchoctaw
Tried searching this and couldn't find anything.
I think that I've read somewhere that on the second gen 1500's you can get 2500 front coil springs and it will lift the front end up 3 inches and then you just put blocks or add a leafs in the rear and new shocks all the way around. Is this true? Will the spring just bolt up to the existing mounts on the 1500 or do I need to get other things from the donor 2500?
Thanks
Thanks
