95 ram 1500 with a 6 inch lift
jboogsram
5.9l v8 magnum
i have my truck thats been lifted i bought it that way and the guy said it needed adjusted with the shift linkage for the auto shifter so i havent the foggiest of ideas on that or the whole lifted truck as far as that goes i want to replace the shocks and springs but dont know where to begin really
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Well I guess that all would depend on why you want to replace the springs and shocks.
Shocks you can talk to one of our very helpful vendors and they can get you the right length of shock for your truck. As for the springs those aren't usually a problem.
The shift linkage is pretty much just adjusting the shifter cable to make it longer or shorter.
J
jboogsram
5.9l v8 magnum
well with my truck i need new springs because the dope that had it before me decided to pull a gooseneck horse trailer with 4 horses and a living quarters in it so they dont smile no more they just kinda flat line is all lol so i need new ones for sure but its my project truck so i want to do it right
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Makes sense. The springs for the rear you can get all kinds of places. They are just a leaf spring pack. But I will say mine was the same until I replaced my shocks. Talk to DB Truck Customs or Moes performance. They should be able to hook you up. Both are great vendors here.
Lift'EmHigh
Ravenna, OH
Summit Racing.
Free shipping(just pay handling)
and they also will try to get them to you in less than 3 days!!
rambob
LA/MS
318 5.2l
there are alot of options with the lift.
need to make sure of what you have...
can we see pictures of the leafs?
are there lift blocks? what size?
are you sure you have all suspension lift, not some body lift?
DB will definately help you out.
J
jboogsram
5.9l v8 magnum
im sure it does have a susp. lift and a body one too and i need to get some pictures of the old beast and put it up here lol
HUNTERRAM
5.2l 318 magnum
If you need to adjust your shift linkage alot, it most likely has a 3" body lift no?...
