give me some tips for suspension work please
the codes
Houston, Tx
Magnum 5.2
Hey guys, gonna be ordering my longer shocks soon and installing my 2" level from top gun customz. Was gonna make sure I have the process right in my head and see what advice yall can offer me to make it easier. This will be my first install suspension wise besides doing the shocks.
So get the tire off...obviously
take shock off
support the ends (so when the control arm is disconnected it doesnt fall and rip the brake lines)
once the control arm has been disconnected, compress spring, take it out, put the spacer on the coil, put coil back in and decompress, and reverse order for everything else..?
Get reallignment
Do I have it right..?
Okiespaniel
Work, Shop, Computer
magnum, 5.9
I hope you will find this either amusing or helpful. This was in response to a similar question asked on another forum.
Perhaps we "assume" that everyone on here has a well stocked garage, some kind of manual, air tools, a plethoria of jackstands and all. Or a bhrama bull, two tree stumps, a stack of pallets and a chain hoist. On our behalf, I apologise.
For me the daunting task is dropping a 300+ lb front axle loose from two coil springs under some preload, while keeping a 6600 lb truck on two jackstands on a slightly inclined driveway. Plus I never have a helper. Thus two jacks.
Your stock shock tower bolts are actually welded to a steel ring that is under the rubber isolator. That doesn't get reused.
I also remove the brake hose brackets so they hang free. You could remove the upper nuts on the sway bar studs but you usually snap one so I try to slip it in without taking them off. The stock upper control arms, by design limit down travel. They'll drop enough to get the springs and spacers in and out.
Be careful you don't tear the isolator, Dodge will sell you 3rd gen replacements which don't fit well. If your new spacers don't have welded on studs getting the holes aligned to slp new bolts in can be a pita. Best to get all three holes aligned...slip a bolt and nut in there finger tight to hold the spacer in place, and put the springs and isolators back in. Use the jacks (or I recommend another pair of jackstands) to hold the springs/spacers in place and reinstall the shocks. Now remove that finger tight bolt. You're over 1/2 done!
Gas shocks are a pain. So I use LARGE zip ties to compress them and hold them compressed. Drop them through the springs and put in the bottom bolts.
Don't forget your washers and bushings on the bottom of the top shock stud!
When you have exhausted your share of cusswords geting the upper shock mounts bolted into the spacers, align the upper stud with the hole in the mount and cut the zip tie.
BTW, you'll need a manual to get all the torque specs. Your lower shock bolts and track bar bolt have to be correctly tightened. A good torque wrench is a must. You could rent one.
Oh, in addition to your axle being uncentered under the truck your sway bar link geometry will be changed. They will angle back towards the spring. No biggie, but under a turn or similar manuever the now unstraight bushings will deflect and the sway bars reaction and compensation will be slower. You should NOT remove the sway bar. Drop brackets or longer links are avalible to restore factory functionality.
Hopefully you will not catch "inch desease". There is no cure.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Once my axle dropped the spring fell out, I did have to compress it to get it back in with the 2.5" leveling, but it would have gone back in with only a 2" and not being compressed
Stangshcky12
Oshkosh, WI
5.9 Cummins
Well luckily he doesn't have an axle to drop lol
Can't really tell ya on a 2wd but it sounds like you have te right idea
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Big frickin hammer will do the trick
the codes
the codes
Houston, Tx
Magnum 5.2
thanks guys, and thanks for the details okie, should help me alot..and I have the manual and jack stands...but oh how air tools would be nice.
Tapatalk Addict
the codes
the codes
Houston, Tx
Magnum 5.2
doing my front shocks a couple months back was a bigger ***** then my ex gf...not looking forward to doing it again so soon haha
Tapatalk Addict
Okiespaniel
magnum, 5.9
I always thought you had a 4wd because you wanted to put 35's under your truck.
Getting a set of those under a 2wd will be a bigger ***** than 2 ex gfs and an ex wife.
the codes
the codes
Houston, Tx
Magnum 5.2
after looking at the prices of 35's I have been thinking I will settle for some 33's. A few people said that with a level and a BL that they got 35's under easily. but yeah I think 33's will suite what im looking for.
ChloeBrooks
