Lift???
gambler2jake
I have a 01 ram with a body and susp lift on it when I bought it I know it has a 3in body lift but how can I measure and tell how much susp lift it has so I know cause I'm in need of new shocks annd don't want to get ones that are not the right lenght
Sent from my ADR6300 using Tapatalk
rambob
LA/MS
318 5.2l
what's your fender measurements?
G
gambler2jake
From the axle to the top of the fender well
rambob
LA/MS
318 5.2l
from the ground to the top of the wheel well arch
G
gambler2jake
44in in the front and 46in in the rear
rambob
LA/MS
318 5.2l
mine is 44.5" - 5" lift with 33" tires
ramhunter is 45.5" - 35" tires - I think his is 5" lift also - 2500 ram
G
gambler2jake
K thanks
rambob
LA/MS
318 5.2l
so you likely have a 2-2.5" front and 3" rear
is there a spacer on top of your coil spring?
G
gambler2jake
Ya and I just measured the back block and your right its 3 so i have a 2.5 or 3 in. Susp lift with a 3in body lift then
G
gambler2jake
So I need shocks for a 3in lift then since body lift don't effect it
ChloeBrooks
