lift kit help
boarderkidd11
i am looking for a 2 or 3 inch lift kit where would i be able to find one that is cheaper? also what would be better?
boarderkidd11
boarderkidd11
i got a dodge ram 2500 block for the rear i think its 1 3/4" bigger than my stock ones. what would i need to do for the front? and also will i need to change anything for the steering like the track bar or anything? will i be able to use 2500 u bolts?
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Tell ya what I did and it came out pretty well. Get a leveling kit. Those are about 100 - 150 bucks depending on what one you get. Then I didn't do blocks in the rear. I kept my stock block and went to my parts store and picked up a set of monroe load leveling shocks. I picked up 2 or 3 inches in the rear and 2 1/2 up front. So looks like a 2 inch left but in fact it's not. That is just a thought.
As far as adjustments no not if you do a level kit and blocks or shocks. If you do the body lift you may have to play with the radiator and the steering not sure never done a body lift. Just some food for thought and welcome to the forum!!
ramhunter9
P-Star Jeep Wrangler
Rule of thumb on a suspension ... anything over 3" you will need to replace a few components .
I would go with the route Vicky went .
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Mine werw around 125 out the door. Work really well. Hauled 3k lbs in the bed no prob. Well worth the cash to me.
Sent from my DROIDX using Tapatalk
mitchman
SC
I got the 2" leveling kit for my old 2500 (same suspension) for $69.00 shipped to my door brand new from TGC.
The rear you can do blocks. Any kit should come with U-bolts. You should never reuse them. Once and done.
Ram 2005
5.9 Twin turbo diesel
Hi There You can have my 3inch kit for free but I am in australia
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I went with the 2.5" leveling kit from Top Gun, and Bilstein 5100 shocks (my shocks needed replaced) My truck has the off-road package so it sits roughly about 2 inches higher than a regular one. I could have went with the 2 inch leveling in the front but I like the way it sits. The ride is very smooth, even while towing my camper.
Also for those people with the off road package, I got the shocks that are for trucks with 2-3inches of lift.
ChloeBrooks
