Need y'alls opinions...
PinkCamoDodge
Out in the Boondocks!
Magnum v8 5.9
Okay so I wanted to do something that would fit in my low budget right now, lol, to add some height to my truck. I found this kit on e-bay that I think I want to order. I can't spend big money right now, so I thought this might be decent.
I would like for y'alls opinions on if it's decent or not. Also, would I need to change anything else on the truck once I install this? Thanks in advance...
94-01 Dodge Ram 1500 2WD Complete 3" + 3" Lift Kit | eBay
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Check with ramhunter at DB truck customs. he could probably get you a kit for the same price.... Plus the shocks required!!
Sent from my VS920 4G
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
Yes, with the added height it will almost max out the stock shocks.
And basically you hit a bump.... You'll compress fine, but when it comes back up it will try to over extend the shock and cause damage to the shock entirely.
05singlecabHEMI
Lilburn,GA
^^ what he said. i put a simple 1.5in spacer and it will hit the end of the shock from time to time.
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
Ok so I had a local gentleman here INSIST that if I do this 3" body lift, that I would have to lift the engine too????
txbass06
NE Texas
5.9 Magnum
Never heard of that before. Most body lifts require you to lengthen the fuel tank filler neck, modify/adjust the fan shroud(if you're using the mechanical fan), and adjustment to the steering linkage and trans shifter linkage
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
Lift the engine....? That is un-true all you are doing is putting spacers from the frame to the body you would Not have to lift the engine as that is not even needed for a BL.
It's a pretty simple process if you have all the right tools
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
Thank you guys.....I do live in the boonies and folks SWEAR they know everything about everything, lol. I just wanted to make sure. I thought that sounds rediculous!!!
ramhunter9
P-Star Jeep Wrangler
That kit I suggested is everything you need to lift your truck 3" front and rear .
EVERYTHING needed ... no engine lifting .. lol thats just the dumbest thing I have ever heard ..
Go find that guy and kick him in the nuts for me please .
If you want to go with that kit just let me know and forward that PM back and we can set ya up the correct way .
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
I will most certainly be ordering that kit from you. Soon as the check arrives that I am anticipating this month, I will be PM'ing you right away and placing the order :D
LOL And yes, I'd love to kick said genius in the nuts sometimes, he drives me crazy everytime I run into him at the service station. That's the ****** part about living in a very small town....you can't easily hide from people, lmao....
ramhunter9
Oh I know ... small town guy here .. I cant fart without the town knowing .
I love it tho .. everyone knows me , cops are friends and football games on Friday nights where everyone is at .
Ramchowder
