RC 5" lift?
syco killer
magnum 5.9l
I was wondering if any of you have this lift and what problems you may have ran into or concerns? What other upgrades may I need?
Ive done research but cant find much on this lift.
Howells
Kitchener Ontario
5.9L
I'm running this lift and works great. No problems with it yet. You will need new control arm bolts as the old ones won't come out. You will have to cut them out. Dealer item. Look into a new trackbar also as the factory one isn't going to last with the drop bracket they supply. It will be okay for awhile unless it's already worn then it show signs very quickly as mine did. Deathwobble. Great kit for the money. Good luck on the install.
Okiespaniel
Work, Shop, Computer
magnum, 5.9
^ This. And ditto on the R/C track bar mount. The one place they went cheap on and yet so crucial...
Plan on investing a proper after market track bar with your lift so you can center your axle. Dodgeoffroad makes a nice one. It's not cheap but is beefier than the competition and will outlast your truck.
S
syco killer
magnum 5.9l
Sweet! Thank you!
I was kinda worried about the rear blocks. Anyone here sporting a 5" lift and 33's?
jsq789
Indiana
Magnum 5.9
Sweet! Thank you!
if you're worried about having enough space you'll have more than enough. I had 33's with the stock 3" block with plenty of room.
Btw the 5" lift gives you a 4" block and 5" of lift in the front to level it. At least it did for me
S
syco killer
magnum 5.9l
I know i'll have enough room. I just wanted to make sure it will look good.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Does anyone have this kit with the adjustable control arms?
I have a set of their Adj. CA sitting in a box and now I'm wondering if I should have gone with a fixed control arm, I'm kind of worried about the threads stripping
ChloeBrooks
