20" wheels fit?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Depending on your tire size they should. I have them on my 01
This is a web image I got, but looks like the stock tire size on the 20
B
billydflnc
LEXINGTON,NC
I knew the ones on the white truck would but I needed to know about the ones on the blue truck .... It seems they do. Thanks for your help
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Yep same bolt patterns on the 20s
B
billydflnc
LEXINGTON,NC
Looking good on both trucks....got to get special lug nuts? What size tires on it? I need something like the Nitto Grapplers ...... Live in the country ..... Rural North Carolina .... Need something to run some dirt/gravel roads
quad_damage
2001 Ram Sport 4x4
What size tires are you rockin werm?
Nice truck btw.
Pete
Howells
Kitchener Ontario
5.9L
i like the 2010 wheels the best.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I was running Nitto Trail Grapplers with 295/60/20s, just under 35"
They are now sitting in my garage waiting on a buyer. I just used my stock lug nuts.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I have a thread around here somewhere with a bunch of photos of newer rims on the 2nd gens.
quad_damage
2001 Ram Sport 4x4
Can you plz post a link to that post?
Also, were you running those tires with only a 2.5" leveling kit?
Thanks,
Pete
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Let me see if I can find it. Yes I have a 2.5" but my truck also is the Off Road package so the springs are stiffer, giving it a lift of 2" over a stock truck. May have to check with others to see what they did to run 35s
Edit: Found it
http://www.ramforum.com/f59/factory_20s-11489/
Big Red Wagon
For those wheels to fit, did you have to modify rims? I have a set off of a 2013 that I would like to put on my 98 sport
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I did not modify anything.
Big Red Wagon
Nothing? I tried real quick one night to put on rear and it didnt seem to want to go all the way on. Will have to try again and do the front this time. Maybe it will be different. I wanted to lower mine some but keep the 20's on if I can. As of now the rear is stock height but the front has two 1" coil spring spacers.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Yep I took my stockers off and put the 20s on, my stock lug nuts too.
Here is with the stock size tire
Big Red Wagon
Your Truck looks good with those wheels, Will have to find some tires and try putting them on again.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Yeah I am waiting for the new owner of the truck to save up and buy the 20s from me still. He currently is running the 17s
my96
1996 dodge ram 1500 2wd
I have a '96 2wd and i got a set of flower pedal 20" wheels that wont go on the front, the center hole in the wheel is not large enough to go over the last quarter inch or so of the spindle. i think i need a spacer.
