rear disc break conversion...
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
My mistake. I haven't done much with the 2nd gens, and assumed they all had the standard 9.25 as well. Many of the newer trucks are going with the kit I linked to allow us to run smaller wheels for drag racing. I know summit also sells a disc conversion kit for the 9.25 that is a little cheaper, so they may also offer their own house brand kit for that Dana 60 as well.
rowdyram
magnum 5.9
Your op on 38.7 Michelin XML Militery tires (yes DOT tire) @ 120 lbs each and 5.36 ratio? Thats the ratio I am looking at going with.
Edit: All severe mountain driving and max speed of 65mph no more towing with this truck.
I think that ratio will work. My math says it will be lower than the stock setup and with those heavy and larger tires I think it'll be fine. I've never heard of the XML but know quite a few guys that run 40" xl's they're nice but go away quick. If your going lower and replacing your carrier you might think about installing 70 parts in the rear. Takes some cutting and welding though.
Merc225hp
NA
truck
gas
No Worries bud, that kit does apply to the 1500 2nd gen Rams so you are not out of place for posting that kit.
1500's have the 9.25
2500's have Dana 60's and up to Dana 80's
Q you have access to 2" dia emulsion 14" travel king coil-overs? Pm me please I think I have messed with this thread enough.
Merc225hp
NA
truck
gas
Did some parts book digging this weekend. I found no diff for master cyld from drum to disc, but remembered a bud that did this swap and he had to change his proportioning valve.
Rear Disc brake part numbers for the Dana 60, 70, 80
52009919AA x2 @ $180 each, This includes the backing plate, parking brake shoes and all the hardware.
Fits
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M60 HD/248MM"+"Axle Ratio - 3.55"+"GVW Rating - "RHD Asia Region Group"0#"-"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete assembly. . "Axle - Rear, Dana M60 HD/248MM"+"Axle Ratio - 4.10"+"GVW Rating - "RHD Asia Region Group"0#"+"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M80"+"Axle Ratio - 4.10"-"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M80"+"Axle Ratio - 4.10"+"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M80"+"Axle Ratio - 3.55"-"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M80"+"Axle Ratio - 3.55"+"Axle - Anti-Spin Differential". Required: 002
ADAPTER. Parking Brake. Complete Assembly. . "Axle - Rear, Dana M70/267MM"+"Axle Ratio - 4.10"-"Axle - Anti-Spin Differential". Required: 002
05018580AA x2 $94 each ADAPTER, Disc Brake Caliper
06504691 x4 Bolt Adapter to Backing Plate,Mounting
05017651AA x8 Bolt, Hub and Rotor
52009932AA ; 05017658AA $126 ROTOR. Brake" DANA M60 HD / 248MM RBI"+"AXLE RATIO - 3.55"+"GVW/PAYLOAD RATING"-A ANTI-SPIN DIFFERENTIAL". Required: 002
Calipers, take note these include the brackets, dodge part #05018580AA
RAYBESTOS Part # FRC11312 $153 Rear Left Professional Grade Professional Grade Friction-Ready Caliper, Remanufactured, Contains Bracket
RAYBESTOS Part # FRC11311 $153 Rear Right Professional Grade Professional Grade Friction-Ready Caliper, Remanufactured, Contains Bracket
Rear disc Pads
RAYBESTOS Part # PGD702AM
Rear brake lines
52009991AA Left
52009990AA Right
06035832 x2 Bango bolt
05015429AA VALVE, Proportioning
