Tire pressure question
PinkCamoDodge
Out in the Boondocks!
Magnum v8 5.9
Ok so I was always under the impression of fillin tires up to the max psi listed on the tire itself. No higher. I'm goin on a decent length trip tomorrow so I wanted to top off my tires. The tire itself says max psi is 80. Somebody I know advised me that it's not safe to fill em up to 80. What do y'all think?? If not 80 like the tire says, what's the proper psi for me to fill 'em to?? Thanks y'all.
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Is that cold or hot pressure? Usulally the tire said max pressure X lbs cold.
A few "depends" here...tire size, rim width, wear pattern.
Example, my tires say 65 psi max cold. But for proper wear pattern and traction I usually run 55 psi front (large tire narrow rim) and 40-45 in the rear when unloaded. That gives me a uniform wear and best on road traction.
AP or AT tires are not quite so finicky as mudders.
Not that you have time but checking a tires "footprint" by running a piece of sidewalk chalk crossways on the tread, driving on a flat as possible surface and checking the width and quality of the "chalk print" can be helpful. A consistant amount of chalk on the tire should leave a consistant mark with no faint or heavy spots.
PinkCamoDodge
PinkCamoDodge
Magnum v8 5.9
My tires are 265 75 16's if that helps.....
ya know.....I just ran outside and looked and I awear it doesn't say 'cold' on there anywhere!
Bluesmoke91
2nd GEN Site Mod
Baldwin Park, California
Are those stock sizes with stock rims? If they are, just check your doorjamb. Tires shouldn't be run at there maximum inflation rating. Faster tread wear along the middle of the tire.
Sent from my DROID RAZR using Tapatalk 2
Workram11
Hemi5.7
That happens when running max psi and not hauling/towing anything. All depends on what you use your truck for. I constantly have anywhere from 1,000-2,000 lbs of tools in the bed or haul about 3,000 lbs. I run 75 front and rear. If you're not hauling/towing anything though I would run min psi listed on the door.
Sent from my iPhone 5 using Tapatalk
Bluesmoke91
2nd GEN Site Mod
Yea i should have cleared that up. Don't run them at high psi without load. I see that on passenger cars all the time at work. Tires are always over inflated.
Yo Nadz
St. Louis, MO
Hemi 5.7 Sport Crew Cab 4x4
what kind of pressures should be run on a 2013 on 20x10 wheels with 35x12.50x20 trail grapplers??
Needaram
SE WI
Use what it says on the door jamb. Or a couple psi higher. Dont use the tire max. psi.
