Gauge LED swap
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
That sounds about right. When you do it if you wouldn't mind making a writeup so we can add it to the diy section.
AWE Daniel
Banned
I dont know. I havent seen a 2nd gen do it yet. What color is factory? Green?
OklaHemi
new age hemi
dont be hating cause you seen my blue
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Im jelous lol but I'll have blue and white, so it'll go right along with the truck
AWE Daniel
Banned
Well the 3rd gens have a blue film in them that turns the yellow light from the halogen bulbs green If you get white, youll probably end up with light blue.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
What if I put blue film on the odom. and the gear indicator, then put white on the rest of the gauges. Think it would work?
AWE Daniel
Banned
Unless you take the thing apart and remove the blue film you cant do white.
AWE Daniel
Banned
I dunno. I dont have the balls to rip it open like that. Getting a replacement for the 3rd gens are tricky and expensive.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
I have looked into this mod before. If memory serves me correctly there is a blue film under the cluster so you would have to pull the cluster and the internal board to remove the film. It can be done but is a lot nor of a pain. All colors are possible in the right intensity. If you had a bright enough LED you could get white. But getting the right color will take some trial and error. So far I have seen red and blue. Most common is blue because of the film. I have seen one red one and they guy took the entire cluster apart to get rid of the film. You can put the okla blue on the odo to make blue I think. Gearshift would be the same as the bulbs.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
I got bored and actually got to that point, but didnt pull the film. It's actually not that bad, so I might do that again so I can get a real white. For the odometer, I think I'll just have to put the film on the back of the cluster and it should work. Same for gear shift
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Yeah, it shouldn't be to bad, just need to get the lights now lol
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
well sweet maybe you could add in the film pulling part for those of us that are leary about it. I kinda like my green. So I doubt that I will be doing this mod anytime soon. lol
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Sure, and like I said, it's actually not all that bad. Took me like 10 minutes and I had it all ripped apart lol so I guess all I have to do is just get ahold of the film and rip it off?
