Guess I should've kept my mouth shut
quietpeen
2021 TRX
Hellcat
that sucks man. From what i hear - its not a matter of if the dash will crack on the 2nd gens. but a matter of when.
Rogan68
Lancaster, TX / Winchester, VA
6.7L Cummins G56 DRW 4WD
There's historical data of MY99-00 trucks getting their dashes replaced in early 2000s; that's how poor the material is.
per Tapatalk on my EVO
txbass06
txbass06
NE Texas
5.9 Magnum
Pretty much lol. If I ever retire this one from being my DD, I'll probably make one out of diamond plate or something and be done with it
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
My 01 was replaced in 03 per the receipt I found in the glove box. I believe it was $1100
rambob
LA/MS
318 5.2l
lol. sorry to hear that.
mine is bad. the PO tore it replacing the heater core, but he said it was cracked before.
my dads was bad also. he replaced it with a $300 one.
both from high humidity, hot climates.
txbass06
txbass06
NE Texas
5.9 Magnum
I need to replace my heater core too...
Heat still works good enough to keep me warm during the "winter" down here so I'll probably wait till spring and order a cover so I'll have it. Just gotta keep a rag with me to wipe the windshield down lol
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
We have had a '95, '98 and most recently another '98 and none had cracks. I wonder if it is heat since we don't have many hot days only warm.
$miley
txbass06
txbass06
NE Texas
5.9 Magnum
I can say that I've noticed more with trashed dashes in warmer climates than cooler ones. My truck was bought new in southern OK and stayed there till I got it last October. There were plenty of 105+ days down here this summer.
Whenever I replace mine, I'm gonna try just hand tightening everything and see if it'll help with it flexing in the next few years
rambob
LA/MS
318 5.2l
I've read to keep the windshield bolts loose.
rambob
LA/MS
318 5.2l
There was also a discussion on if Armorall type products speed up the process. Making it brittle.
rambob
LA/MS
318 5.2l
I used black duct tape to put mine together. I plan to get a dash mat one day.
Badger
Bettendorf, IA
I heard about this problem on Chevy cavaliers so when I got mine new I. 2002 I puuled all the bolts and put rubber washers in on both sides of the plastic. It never cracked and I sold it in 2009? I think. But it worked and I had zero squeaks or rattles. Maybe that is the solution.
Trupiano
Registered User
6.7L CTD
That sucks bud. I don't think new dash covers are that expensive. Just food for thought: On my 05, I bought a windshield shade so my dash wouldn't heat up and crack like that. Put just about 100K miles on it and never had a problem. Maybe it would be a good idea?
Mopar1973Man
New Meadows, Idaho
From what I understand about the problem is the plastics don't hold up to extreme heat and bakes the oils out of the plastics and becomes brittle and breaks from vibration.
This is most likely why I don't have the problem because summer heat here might get to 100*F but rarely is the truck left out in the sun for long periods. If so like traveling to Boise, ID for shopping then I will use a sun shade to reduce the dash temps.
Out for curiousity I place a digital themometer on the dash with a dash shade you can still see roughly 120-130*F on the dash on a hot summer day. Even worse without a shade... (Ekkkk!)
txbass06
txbass06
NE Texas
5.9 Magnum
I'll probably buy one of the sun shades when I buy the dash cover. Gonna get some tint too so maybe that'll help keeping the temps down in the cab during the summers down here
Mopar1973Man
New Meadows, Idaho
Actually better yet to leave both rear windows open or roll down the front windows about 2" from the closed position. As long as the heat can get out the temps can build up. Then if the sun can shine directly on it also stay cooler...
txbass06
txbass06
NE Texas
5.9 Magnum
I do crack the front windows but never thought about opening the backs lol
Rogan68
I open my QC windows, and vent the fronts, but I always forget to close the 1/4 glass, usually after it rains I remember...
ChloeBrooks
