Instrument panel lights
ramthis9501
Oklahoma
5.2 V8
Anyone know what kind of led lights an 01 ram gauges take? I'm wanting to do the tach and all that. Thanks
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
You trying to go and change the color huh? Well you can get some led's from here: Super Bright LEDs - Miniature Wedge Base Bulbs
They have all the parts I believe to dot he conversion. I have seen it done several times and it seems pretty straight forward.
But there are different bulbs for different lights. But all the cluster bulbs should be the same i.e. the tach, speedo, gas, temp, oil, and battery. These should be the bulbs to get.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/specs/WLED-x5.htm
AWE Daniel
Banned
if you can take out a bulb and post a pic of it then we could make sure which base you want
AWE Daniel
Banned
that looks like the b8.5 series base, just like the 3rd gens. Once oki has his DIY up it should pretty much be the same for you, just 2nd gen differences
OklaHemi
new age hemi
those look more like the neowedge to me see the plastic tabs. that is similar to the ones that go into the overhead. give me a bit colton ill see what i can find
AWE Daniel
Banned
Maybe, its been awhile since i had the dash apart, but i remember the other ones having tabs also
ChloeBrooks
