Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Sponsored Ads
Register to remove these ads.
Considering some Mods for my tired 5.2
This is a discussion on Considering some Mods for my tired 5.2 within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! Guys (and Gals), Over the past few years I have been noticing my ...
Reply
Old 02-03-2012, 08:05 PM   #1 (permalink)
Ram Year: 2001
Engine: 5.2L
Default Considering some Mods for my tired 5.2
Guys (and Gals),
Over the past few years I have been noticing my 2001 Dodge Ram 4x4 has been subtly loosing power. Finally, a couple weeks ago it developed a "tic" in the top end. I pulled the valve cover and found the problem. The left rear lifter is dead. With 145,000 miles on the old girl and over 1/2 towing a trailer or boat, I think it's time to freshen her up and try to regain some of my lost ponies. When I opened up the valve cover, the first thing I noticed and was rather surprised was some baked on sludge on the rockers and guideplates. I could hardly believe it since I am very meticulous when it comes to my routine maintenance. I always have changed the engine oil on regular intervals. When the truck was new I used a 5,000 mile interval and once I turned 75,000, I dropped back to 3,000 mile intervals. 10W-30 Castrol has been used since the first change and I never had any oil related problems. I did have to change the oil pump at about 130,000 after a couple "check gauges" warnings popped up but the oil pressure would come right back up. That being said I only drove a couple miles and had it roll backed to the garage to be fixed. I don't understand why the baked on oil was present but it will definately be cleaned well during this teardown. Anyways, back to the problem at hand. Instead of just fixing the lifter problem, I am seriously considering a few mods while I have the top end tore down. Below is a list of planned mods. I would just like to get a few feedbacks from some fellow MOPAR maniacs on what I am planning on doing.
Hughes FI Airgap Kit
Big Gulp TB
Hyd Roller Lifters
Timing Chain Set w/ 3 Keyways
Chain Tensioner
Accel Distributer Cap
Accel Distributer Rotor
SCT Tuner
Of course, when I remove the intake, I will have to clean up any baked on residue that may be down that far. I hope it was just on the rockers and didn't get down to the heads. I also plan on pulling the heads and having them disassembled, cleaned and ground. Of course, new valves, guides, seals and springs while I'm there. I know you guys are going to say if you're going to do the heads you may as well go with a cam, clear the pushrods and valve lift while your prepping the heads and slap on a nice set of headers. Believe me guys, if I can convince the powers that be (my wife) I would put a set of Hughes heads and headers on her, a mild cam and be done with it. I will probably wish I would have done it in 6 months as we all do when we are on a budget. With the above mods, the necessary gaskets, fluids and help of a good friend who happens to be a retired MOPAR mechanic, I am probably looking at close to $2000. My goal is to regain the HP the 5.2 had when she left the factory...or maybe just a little more so pulling my lawn equipment trailer and boat isn't such a strain on the truck and granny doesn't blow the horn and flip me off going up a hill. I just want to enjoy driving my truck again and getting the performance out of it that it is capable of producing.
So guys, lets hear your 2 cents on the mods, good or bad or heading in the right direction. I would like your opinions.
P.S. Sorry to be so long winded but knowing some history always helped me to make decisions or add some weight to them. Hope the info helps jog some memories or make suggestions so others will find the information useful.
lildevil1966 is offline   Reply With Quote
Old 02-03-2012, 09:38 PM   #2 (permalink)
Okiespaniel's Avatar
Ram Year: 2000
Engine: magnum, 5.9
Default
I don't know how far you are into the teardown yet, but if it were my truck I would do a compression check first to determine if your rings or valve guides are leaking. Blowby could be causing you "sludge" issue.
If the compression is well within specs, you could add these mods. But I'm believing based on your oil pump issues and the amount of sludge you found, that this motor is in need of more attention.
I would not waste my money on Hughes heads for a motor with such mileage and history before redoing the bottom end. The increased compression your massaged heads adds to a set of worn out rings will decrease your power considerably and you'll use more oil. My experience is that is gradual but when the blue smoke comes rolling out you're done.
Bad lifter(s) are another sign of the same issues.
If if were my motor, based on what you've written, I would fix the obvious issues, button it back up, toss the headers on for looks, and start buying the pieces for a total rebuild. Put the Hughes heads on a bottom end capable of wringing every ft/lb of torque and every last horsepower makeable.
And yes I have tried this (and failed ) before....But only once
I think I will go out and hug my trruck tomorrow. At 140 k no oil pump issues, no bad lifters...and I use Castrol 10-30 dead dinosaur.
__________________
Life is a Highway...I wanna drive it all night long...
Okiespaniel is offline   Reply With Quote
Old 02-03-2012, 10:32 PM   #3 (permalink)
Mopar1973Man's Avatar
Cummins Diesel Section Mod
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default
Okiespaniel, Very Wise man...
__________________
Michael Nelson - RamForum.com Cummins Moderator
2002 Dodge Ram 2500 Cummins - Mod List ~+~ Pulling 2000 Jayco Eagle 296 FBS ~+~ 1996 Dodge Ram 1500 5.9L V8 - Mod List
Mopar1973Man is offline   Reply With Quote
Old 02-03-2012, 11:00 PM   #4 (permalink)
Ram Year: 2000
Engine: magnum, 5.9
Default
Thank you sir!
__________________
Old 02-04-2012, 10:52 AM   #5 (permalink)
Hotroder383's Avatar
Ram Year: 1996
Engine: 318 or 5.2 which ever you want
Default
I'd agree no use puttin all that on an engine with issue as you said. It would waste money and you'd not see the power gains you hope. Save it and buy a rebuild kit from PAW. Myself I'd pull the engine, tear it down check bore and deck to see if it needed machine work then order the rebuild kit, this so you dont order rings and find out on tear down that you need to bore it .30 to get rid of a scratch in cylinder wall. But I have a second car to drive while doing all this =) Now if I just had the money to do it I'd be in heaven LOL
Hotroder383 is offline   Reply With Quote
Old 02-04-2012, 12:09 PM   #6 (permalink)
MikesRammin's Avatar
Ram Year: 1994
Engine: 5.2 Magnum
Default
X2 on what they said but also I don't know how effective a 3 key way timing chain would be on this build because unless you go straight up I think it would flub up the cam position sensor and computer.
__________________
1994 Dodge Ram 1500
5.2L 318, TB mod, true duals straights, EGR Delete
Loud and proud baby!
MikesRammin is offline   Reply With Quote
Old 02-04-2012, 04:14 PM   #7 (permalink)
Ram Year: 2001
Engine: 5.2L
Default
Thanks Okie, I'm not into the teardown yet so checking the compression will be done after supper tonight. If all cylinders check out with good numbers and things are clean in the bottom end should I assume the bottom end is OK.
Like I said in my original post, I would rather not pull the engine if it's not necessary. I have never notice any "blue smoke" that's usually a sign of rings or valve problems. I think if I have to do a rebuild I may have to back off some of the mods and get the motor back up and running. After that who knows, it may have to stay in someone else's driveway. Hopefully it won't come to that, I'm the original owner and she's been a good truck for 11 years now. It would be hard to replace her.
Old 02-04-2012, 07:05 PM   #8 (permalink)
Ram Year: 2000
Engine: magnum, 5.9
Default
Gettting the motor back up and running should be your priority for now. The motor has too many miles on it for modding.
You won't notice any smoke at this time because you haven't increased your compression significantly...in othe words all your wear surfaces are wearing evenly. Mods on old motors can be quite stressful...the same analogy can be used on all the warnings applied to a bottle of Cialis.
__________________
Old 02-06-2012, 07:57 PM   #9 (permalink)
Ram Year: 2001
Engine: 5.2L
Default
Okie, I did the compression check and things looked good. All pressures were within limits and also within 5% of each other. #1 158 #2 153 #3 157 #4 151 #5 151
#6 152 #7 151 #8 153. I thought all looked pretty good. I think I will tear it down and proceed with changing the lifters and see what the lower end looks like. Depending on the condition of the cylinder walls will determine what I do when putting it back together. I understand the mods will produce more compression on the pistons and rings and other intregal parts but I will have to see what they look like when I get there. I know I have some cleaning to do and will possibly have the heads machines and valves ground/replaced since I am in that far already. In your opinion and any others who may chime in, if everything looks good would you take a chance with the mods or go ahead and pull the whole engine and rework the bottom end before moding. I would still like to get rid of the plenum since its a thorn in the side anyways. With a limited budget, I don't want to create more problems that will dig deeper into the pocket than I want to go right now. Thanks for the help.
Old 02-06-2012, 09:21 PM   #10 (permalink)
Ram Year: 2000
Engine: magnum, 5.9
Default
I still wouldn't spend my money on new heads...clean up your old ones and hope for the best.
At this point it's pretty much your call...I find that when people ask for suggestions on the 'ol internet, they pretty much have made up thier mind and are hoping for justification. Somtimes they get it, and sometimes they don't.
Either way, they pretty much do what they had in mind to begin with and the reason I know this is because I have done it too. It's probably why you'll not see me ask opinions/suggestions about something, I'll simply do it and record the results.
BTW, I'm not trying to be mean or nasty, it's simply the way I've observed things.
And I'll hope that you'll repair your truck and in a few weeks or months from now reopen your thread and report what you've observed. That way others in your situation can read firsthand about a real world application. No one'll point fingers or laugh.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
VP44 problems - Getting tired of the BS! Mopar1973Man VP44 Pump 3 10-24-2011 11:43 PM
Tired something new BMRbrnSNRbrd Photoshop 14 09-30-2011 08:44 AM
A few more mods Ms.MagnumSLT Interior 29 03-28-2011 07:28 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
