Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Sponsored Ads
Register to remove these ads.
Considering some Mods for my tired 5.2
This is a discussion on Considering some Mods for my tired 5.2 within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! Okie, Thanks again for the reply. I went ahead and ordered the parts ...
Reply
Old 02-07-2012, 06:34 PM   #11 (permalink)
Ram Year: 2001
Engine: 5.2L
Default
Okie, Thanks again for the reply. I went ahead and ordered the parts today to fix the lifters and forget the mod for the time being. I will have the heads reworked since I'm in there and take care of the plenum gasket on the way out. Taking your advice, without doing the bottom end I may cause more problems than it's worth at this time. A new timing chain is in order along with t-stat, distributor, and button. A few other maintenance items will be changed that are OEM while I'm there. Beleive it or not, on the way to the shop the damn lifter quite ticking. I was almost tempted to turn around and go back home. Since I already had the funds set aside I figure to go ahead with the repair since it's likey to return. I'll post the results early next week but should be nothing special. Again, thanks for the advice and unlike some, I usually listen to good advice since in the past I didn't and I paid for it as well. Now...go hug your truck...lol
lildevil1966 is offline   Reply With Quote
Old 02-07-2012, 08:48 PM   #12 (permalink)
MikesRammin's Avatar
Ram Year: 1994
Engine: 5.2 Magnum
Default
Could it by any chance be an exhaust leak? I've had them before sound exactly like a lifter.
__________________
1994 Dodge Ram 1500
5.2L 318, TB mod, true duals straights, EGR Delete
Loud and proud baby!
MikesRammin is offline   Reply With Quote
Old 02-08-2012, 08:13 AM   #13 (permalink)
Ram Year: 2001
Engine: 5.2L
Default
Pulled the valve covers and found the rocker assy on the drivers side rear loose. Removed the rocker arm and push rods and the exhaust lifter was stuck. Hopefully a new set will have her purring again.
Old 02-08-2012, 09:48 AM   #14 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
Originally Posted by Mopar1973Man View Post
Okiespaniel, Very Wise man...
x2.
__________________
2001 RAM, 5.2l, 5" LIFT, 33" BFGs, 100 wt yellow fogs, all base model
rambob is offline   Reply With Quote
Old 02-23-2012, 09:40 PM   #15 (permalink)
Ram Year: 2001
Engine: 5.2L
Default
Well, finally got the ole truck back up and running. Job went very well and wasn't to bad on a rookie. The only hold up was having the heads reworked and my shop dragged their feet a bit but having a Dakota as a backup was a lifesaver. Tore everything down in just under 3 hours and took all the parts to work for a steam bath and bead blast. Looked brand new when I got through. After I got the heads back it took about 2 1/2 hours to get everything back together. Turned the engine over maybe 3 times and she roared back to life and no lifter noise. I guess I will drive her a couple hundred miles and change the oil and add some Slick 50 to the replacement oil. She does seem alittle more peppy but I haven't stepped on it hard yet. We'll see in a week or two how she does with a trailer behind her. Thanks for the advice and help making the decision on the mods. Right now I think stock is OK.
Old 02-24-2012, 07:56 AM   #16 (permalink)
Hotroder383's Avatar
Ram Year: 1996
Engine: 318 or 5.2 which ever you want
Default
Glad to hear it. I have done mods on motors with high mileage before with mixed results. I am at the same spot with my truck, I pulled the intake, took out the center section, cut down the runners, and took some out of the injector port for a straight shot. It had a K&N cai on it already and I just did a MSD 5 and Blaster 2 coil last night. These all helped lower end but truth be told if I didn't already have all the parts I would have been very disappointed in results due to lack of a tuner.
You put too much strain on the lower end with 100K+ miles on it and even if your rings looked good before the extra pressure would ruin them alot faster. besides you did most of the hard work already, that far down it is nothin to finish pullin block and doin rings and bearings! A few rules to keep in mind but you ever do post it up here lots of people including me be glad to give you advice!
Hotroder383 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
VP44 problems - Getting tired of the BS! Mopar1973Man VP44 Pump 3 10-24-2011 11:43 PM
Tired something new BMRbrnSNRbrd Photoshop 14 09-30-2011 08:44 AM
A few more mods Ms.MagnumSLT Interior 29 03-28-2011 07:28 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
