Hotroder383
- Jan 7, 2012
- 235
- 5
- Washington Mo
- 1996
- 318 or 5.2 which ever you want
Ok so today I tackled the conversion to electric fans. Made the brace, bought the wireing relay from Summit, and got a pair of fans off a Ford Taurus. Took a few pics and only ran into a couple of problems. Biggest one was the alum I used was not thick enough. I should have used 1/16 instead of the sheet I had. I reinforced it with alum bracing but if I would have just bought the 1/16 sheet I would have saved myself alot of trouble. The other two were the overflow tank and windshield washer tank as both were attached to the shroud. I will need to make a couple of brackets to mount these. The last was were to place the relay, I had planed on putting it on the passenger side, but do to the short lead on the sensor I had to put it on the driver side.
i will do a write up on the install and step by step next week, this weekend is just too busy. I'll take a few more pics of bracing on plate and where relay went and how I mounted tanks. For now here you go enjoy and please comment.
