ram15
today i picked up a fan out of a Thunderbird, the reason i grabbed it was cause i saw that it had a 3.8. it looks like the right fan but i had some questions about it. when i cut the wires i did it as far back as i could reach, it has the blue red and ground but further back the red split into 2 wires. do i need the split or should i cut it before it? question 2 is do i need the stock ram shroud or should i just use the one on the fan? last question is what controller should i use, i only found one 2 speed controller and it was on ebay.
