Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Sponsored Ads
Register to remove these ads.
High Engine Idle
This is a discussion on High Engine Idle within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! Tis?...
Reply
Old 01-13-2012, 11:34 PM   #11 (permalink)
Ram Year: 99
Engine: v8
Default
Tis?
camoman214 is offline   Reply With Quote
Old 01-14-2012, 02:38 AM   #12 (permalink)
Rogan68's Avatar
Ram Year: 2001
Engine: 5.9L CTD 24v 6 hole Bolt-action
Default
Sorry, autocorrect struck.. TPS not tis.
per Tapatalk on my EVO
__________________
'01 QCSB 5.9L Cummins - 6speed, Edge Juice w/Attitude, BHAF, 5" Diamond Eye TBE
'96 SCLB 5.9L Cummins - #10, BHAF, 4" DP, 7" Miter Stack, Leveler, 4500, M275s, Jake
'03 QCSB 4.7 2WD - all original, 98k mi., dual exhaust - My late father's truck. RIP, pops! 4/11/36 - 3/26/11
Rogan68 is online now   Reply With Quote
Old 01-16-2012, 01:37 AM   #13 (permalink)
Ram Year: 99
Engine: v8
Default
Reset unsuccessful.
Old 01-16-2012, 10:28 AM   #14 (permalink)
Mopar1973Man's Avatar
Cummins Diesel Section Mod
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default
Originally Posted by camoman214 View Post
Today I unhooked the battery again for 12 hours to reset the ECM, but still idles high. You said to reseat the TPS.. do you mean just remove it and reinstall or is there a procedure for reseating?
Any other thoughts?
I wish that myth would go away... Unhooking the batteries doesn't reset any computer or erase error codes. Everything is permanently programmed on PROM chips and the code will never be change or altered unless you happen to have a DRBIII tool from dealer.
Disconnecting Batteries and crossing cables - YouTube
The only thing that is lost is throttle calibration.
__________________
Michael Nelson - RamForum.com Cummins Moderator
2002 Dodge Ram 2500 Cummins - Mod List ~+~ Pulling 2000 Jayco Eagle 296 FBS ~+~ 1996 Dodge Ram 1500 5.9L V8 - Mod List
Mopar1973Man is offline   Reply With Quote
Old 01-16-2012, 11:01 AM   #15 (permalink)
Ram Year: 99
Engine: v8
Default
Oh, I did not know that. I always thought it would reset and lose the stored info. Do you have any ideas of what I should try next?
Old 01-16-2012, 02:10 PM   #16 (permalink)
Default
This isn't 100% but the ECT coolant sensor will alter the idle on the Cummins diesel for warm up I assume the same should be true on the V8 gasser series so if the coolant temp is too cold it will idle high and if the coolant temp is too hot it will idle low. This can be verified with a live data tool like a Scangauge II.
As for other thing I would look at vacuum leaks, IAC in the throttle plate, etc... Because technically the throttle plate are closed completely and the fuel/air ratio is controlled by the MAP sensor and O2 sensor to keep a clean idle by giving air or giving fuel so if there is too much air leaking in (vacuum leak) to keep the mixture correct it will add fuel hence a high idle will occur.
As for the battery disconnect... Just think of the PCM like a thumb drive on your laptop... You write information to the thumb drive then remove it and place it in your pocket (battery disconnected) then some time later (even years later) plug it back in and the information is still there just the way you left it. The PCM follows this exactly. The only way to reboot the PCM is turn the key OFF and wait a few minutes and start the truck again the PCM is force to do a reboot and used store programming in PROM (Programable Read Only Memory) which requires a Dodge DRBIII tool to even alter, change or flash entire PCM.
Now I know older vehicle like my 96 dodge has the ability of dropping the error codes with disconnecting the batteries. But this is not fully true either because you might of wiped out the error codes but a flash code 12 remain alerting a tech that you cheated and pulled the battery to hide error codes. So even that is not a fool proof way of erasing...
__________________
Old 01-27-2012, 11:34 AM   #17 (permalink)
Ram Year: 99
Engine: v8
Default
This is some great info.
Sorry for my slow reply. I really appreciate everyone's help on this forum. Thanks.
Old 01-27-2012, 02:21 PM   #18 (permalink)
Rogan68's Avatar
Ram Year: 2001
Default
I've used spray carb cleaner to find vacuum leaks in the past
__________________
Old 03-19-2012, 12:55 AM   #19 (permalink)
Ram Year: 99
Engine: v8
Default
Thanks for all the replies. Turns out there was a frayed wire leading from the IAC to the PCM that caused my high engine idle.
Reply
Bookmarks
Tags
5.9 with high idle, high idle problem, possible vacuum leak
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
high idle on Ram 1500 4.7 timbec6871 Engine & Performance 2 01-22-2012 11:06 PM
Low idle OMALLEY_808 Engine & Performance 2 11-27-2011 09:25 AM
High Idle ktm1217 Engine & Performance 6 11-17-2011 10:12 PM
Winter is coming - Need a high idle kit? Mopar1973Man VP44 Pump 7 09-12-2011 06:23 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
