I Really Need Your help Guys!
ram15
Mendocino, Ca
so today i was gonna go get some new tires but after a while i noticed something was odd about my engine. i babied it a little longer until i got to a hill and discovered that it was really down on power. Whats happening is when i need to get on the throttle to pass someone or go up a hill it bogs down and i lose all my power.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
no codes? any recent changes in plugs, wires, fuel pump, etc...maybe collapsed cat?
05singlecabHEMI
Lilburn,GA
take off your intake and see if there is any oil in it or behind the carb.
ramhunter9
P-Star Jeep Wrangler
And get it scanned for codes , even if there is not one showing there will be some stored
R
ram15
Mendocino, Ca
i haven't checked for codes yet but i will. my cat does have a rattle but im not sure how bad it is. i was also thinkin maybe a fuel filter.
Hotroder383
Washington Mo
318 or 5.2 which ever you want
I'm leaning towards plugged cat/muffler. Also watch your temp as this problem can and will over heat your engine if your not carefull!!!!
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
I beleive x 2 on the plugged cat. stick your hand on the tailpipe and that should give an indication, otherwise a muffler shop can cut in to it for a quick look to see what the honeycombs look like or if they are melted/bunched up like the fellows are saying. Good Luck!
R
ram15
Mendocino, Ca
is it safe to run it like this for a while or should i just leave it be. it hasn't been getting hot at all.
Hotroder383
Washington Mo
No, not safe at all. The longer you run the more chance you got of screwin somethin up. Your engine builds heat from not being able to get rid of the exhaust, so it starts building heat in an area that was never really meant to get That hot <that hot being a relative term with exhaust> It is fairly easy to check out, as 03Mopa said put your hand over tail pipe should be lots of pressure instantly if it dosent then chance are real good you got problems. If nothin else get a bit of straight pipe and pull the cat off replaceing it with staright pipe. Your truck will through engine codes but if it dont bog down then you found your problem, it it still bogs you can always put cat back on, eaiser if cat is slip jointed on and not welded.
R
ram15
Mendocino, Ca
I talked to a guy at the local dodge dealership and he said it would be 165 just to see whats wrong, that's ridiculous. he also said that if it was the cat a engine light would come on. i just wanted to double check if that was true cause it hasn't come on yet.
R
ram15
Mendocino, Ca
has anybody had to replace the cat, how difficult would it be. mines welded in right now but i could probly use clamps if i did it myself.
schroederMP
Indiana
Cummins
My x bro in law had the same thing happen to him...last a lot of power. Had to keep it to the floor just to keep it at 55... it was a plugged cat. Switch that out and you'll be fine.
JET
Arlington,Texas
1996/2011 Ram 1500 Sport
5.9 Magnum/Hemi 5.7
Yea my 96 did the same thing. Cat came apart and sounded like metal flapping in the wind. killed the power. Went to a local muffler shop and the replaced it for 250 I believe. Been awhile. Was more expensive because of the configuration of the Cat. 2 n 1 out configuration. Said a 1 n 1 out would have been half the cost.
Hotroder383
Washington Mo
R
ram15
Mendocino, Ca
If its my fuel filter can i just replace it or do i have to replace the whole sending unit.
Hotroder383
Washington Mo
When I search Fuel Filter it says call store, when I search FuelPump/strainer it shows two parts starting at $220 so your best bet would be to call your local auto parts store and ask them. Or if you can get ahold of a Fuel pressure gauge like this Master Fuel Injection Pressure Test Kit You can check it yourself. With out takeing everything apart. You may be able to find an Auto Zone, O'Riellys etc that will loan you one too.
txbass06
NE Texas
5.9 Magnum
The only fuel filter on our 2nd gens is the strainer on the bottom of the pump in the tank. So to change the filter, you would have to drop the tank.
I'm leaning towards a clogged cat as well. If you want to change the filter first, I would definitely check the fuel pressure before you dropped the tank for nothing
ChloeBrooks
