Original motor?
ltfd22
North Carolina
How can I tell if the motor in a 97 or 98 is the original motor? I cant find a clear answer on this so I was hoping to get some clarification here. Any info is appreciated.
ktm1217
White Mills, PA
5.2L 318ci Magnum
Not too sure how youd find that out. As far as i know, the 5.2 and 5.9 are the same motor on the outside. I think youd have to take it apart and measure bore and stroke on it and compare it to specs. Im sure other guys will chime in, but thats as far as i can tell you. You could also get your build sheet from Dodge.com using your VIN and find out all the options your truck was built with, but that still wouldnt tell you the size of your motor if a previous owner had swapped it out..
ltfd22
ltfd22
North Carolina
Yeah. I was just wondering if the vin was located on the motor somewhere or if it had other numbers on the motor that would match up to part of the vin. I cant find anything on this. Thanks though.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
If it was not original I am sure you could and would find at least some sort of stamping that states remanufactured or some brand of rebuilder name there are many out there. What is the concern you are running into?
ltfd22
ltfd22
North Carolina
Not really any concern since the truck only has 129,000 miles. Just curious and thought it might come in handy to know one day.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I would bet at that low mileage it is almost certainly original the 5.7L HEMI is a 250k plus motor unless ram without oil or water damage or something.
$miley
Elanora
USa
Not sure how you'd discover that out. As far as i know, the 5.2 and 5.9 are the same engine on the outside. I think you'd have to take it apart and evaluate carried and action on it and evaluate it to specifications. I m sure other people will chime in, but that's as far as i can tell you. . . . . . . . . . .
ChloeBrooks
