Oliver
- Jun 23, 2017
- 25
- 2
- 1996
- 5,2 V8
hi all,
just comming on this forum, i am from Europe where it is a bit more difficult to get the "right information".
i went to a friend yesterday to have a look on the the pressures on my engine.
This is a ram 1500 V8 magnum 5,2 gas from 1996 ... 238 000 miles.
the initial pressure ration should be between 150-170PSI ... two of them are at 135 and 145 PSI. The problem is located at piston rings.
My question IS ... is it possible to remove the pistons from below ? witch could be my preferred way ? ... (easier).
notice ... if there is already some information or post about that here ... copy paste the adress please and apologise for dual posting about.
CHEERS ! ;-)
CHEERS ! ;-)
