Hey guys
I have a situation with mutt 1997 dodge ram 1500. All of a sudden it stalls out on me. It shudders and sputters like I'm running out of gas. I had AutoZone pull codes for me earlier today. They pulled the following: P0441 I then replaced the gas cap but it could be other things regarding this code. The next code they pulled was P0740 which came back as torque converter clutch circuit. I then put in transmission fluid but it could be something else. The last code they pulled was P1757 which came back as governor pressure above 0 PSI when vehicle isn't moving. ??? What's crazy is when I put the truck in 1st or 2nd gear it doesn't stall. Why is that. Please help with any suggestions. Thanks much.
Joey 7
Joey 7
