removing the cylinder head
dakota1820
So I have decided I am going to have to pull the head off. I guess once I pull the head off I will take it somewhere to have the plug removed. I read a write up but all it said was to remove the alternator, wont the ac compressor and bracket and p/s pump need to be removed? I am doing the driver side.
If anyone has a write up on it I would appreciate all the help I can get. Its a 95 with the 5.9.
D
dakota1820
It wont let me open the file. I downloaded it but it wont open.
D
dakota1820
If I did that rigjt it said it would cost 9.99
D
dakota1820
I think this ram hates me, in the back of my mind I keep wondering if a shop could somehow get the plug out without pulling the head.
D
dakota1820
Yea, I may go ask a local shop tomorrow I really can't drive it though. I mean I can if I have to but it's probably not real good for it
HolyRamBatman
Deep in the Heart of Texas
If you can start it and let it run for a few minutes it should heat up the plug and you MIGHT be able to remove it. If it won't come out easy after heating it up take it in. Whatever you do DON'T make it worse. Good luck
