I have an 84 dodge power ram and I bought a 360 magnum sourced from a 99 dodge durango that I'm going to rebuild and put in my ram.
For the magnum I'm pretty much getting new everything. The heads are the most expensive part of this build and I've narrowed it down to these two:
Hughes Engines
Hughes Engines
Between the Indy Max and the Iron Ram, which do you think is the best? I've heard good things from both, but I'm unsure which to go with.
What I'm aiming for is exactly what this guy did: 1987 Dodge W150 5.9 Magnum Engine - YouTube
Hughes Engines
Hughes Engines
