Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
Sponsored Ads
Register to remove these ads.
Transmission work
This is a discussion on Transmission work within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! How many have you have had something done? What were your symptoms, and ...
Reply
Old 01-20-2012, 12:07 PM   #1 (permalink)
wermbang's Avatar
Site Administrator
Ram Year: 2001 Off Road
Engine: 5.9L V8 Sport
Default Transmission work
How many have you have had something done? What were your symptoms, and the solutions? Complete rebuild of tranny with new torque converter? solenoid replacement? other part replacement?
__________________
RamForum.com Administrator
Superchips 3715;3rd gen 20s; Cat back exhaust, no muffler;Custom Grill Insert; SRT Hood; Hummer Nerf Bars (PD);Roll Bar (PD); Halo Projectors w/ 6K HIDs; Tow Mirrors; Body matched antennae base and handles; Custom tail Stripe; Custom decals; Painted frame, suspension parts, and wheel wells; Air Horn; Aluminum fuel door; one of kind dents and scratches; 2.5" TGC Leveling Kit; Bilstein 5100 Shocks; LED dash lights ;Cleared needles; blue switches; Painted dash pieces; Pioneer CD player; Cerwin Vega 6x9s , Alpine 5 1/4;Kenwood amp; Boss sub w/Boss Amp; 5% window tint on the back, and strip on the front;[/COLOR]
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
wermbang is offline   Reply With Quote
Old 01-20-2012, 01:01 PM   #2 (permalink)
smiley3303's Avatar
Ram Year: 2009 Ram 1500 Laramie Crew
Engine: Hemi 5.7L
Default
Solenoid was the sign on 98 we had and since my dad kept driving and did not take it. Full rebuild or replace with used had to happen. We got one from a cash for clunkers trick $1400 installed.
$miley
__________________
smiley3303 is online now   Reply With Quote
Old 01-20-2012, 01:04 PM   #3 (permalink)
Hollabakzach23's Avatar
Ram Year: 1998
Engine: 5.2
Default
I have yet to have any work done yet but mine seems to surge out and bog down from 2000 rpms to like 1200 once i hit like 50 mph but if i gas it a little harder it will accelerate fine and drive on.
Hollabakzach23 is offline   Reply With Quote
Old 01-20-2012, 02:12 PM   #4 (permalink)
rambob's Avatar
Ram Year: 2001
Engine: 318 5.2l
Default
I sent out abunch of email describing my issues and got a few good responses. I started emailing the big online retails of rebuild transmissions. the few mentioned on here. its was worth a try and a few replied with some good info.
the local shop, that puts adds on CL, has yet to reply.
__________________
2001 RAM, 5.2l, 5" LIFT, 33" BFGs, 100 wt yellow fogs, all base model
rambob is offline   Reply With Quote
Old 01-20-2012, 10:18 PM   #5 (permalink)
Okiespaniel's Avatar
Ram Year: 2000
Engine: magnum, 5.9
Default
I had an overdrive selenoid CEL for a couple years, then had a shift kit and all new selenoids done. Had I not moved that summer my tranny might have lived. Bu
But it didn't.
1800 bucks all rebuilt, HD clutches, new converter (lockout clutch facing gone) and deep pan. Still gets a bit too warm when towing large loads.
Needs gears.
__________________
Life is a Highway...I wanna drive it all night long...
Okiespaniel is offline   Reply With Quote
Old 01-23-2012, 05:21 PM   #6 (permalink)
wermbang's Avatar
Site Administrator
Default
Emailed a guy on craigslist:
He will take a look at mine for free to see whats wrong with it before too, I just need to get out there to him.
Pending on the condition of the transmission i can rebuild it for 600 plus a converter 120 for a dacco or you can up grade it (dacco is basically a stock dodge with minor upgrades). Billet converters run anywhere from 350 - 500. Or a lifetime warranty pure performance triple disk converter for 1300. Other than that a i would recommend a couple hundred dollars for aftermarket good stuff! This will make this transmission hold 500hp all day long and it will fix all of the factory "flaws" Either way i put a 1 year warranty on it but aftermarket parts will prolong the transmissions life!
__________________
Old 01-30-2012, 11:57 AM   #7 (permalink)
wermbang's Avatar
Site Administrator
Default
So no other 2nd gens have had tranny work done?
I think I am going to try and budget about $1200 for the rebuild/install. What do you think? I am hoping to have some extra funds thats why its at $1200 so I can use the rest for some tuneup stuff. and I figure a couple hundred for that stuff
__________________
Old 01-30-2012, 12:08 PM   #8 (permalink)
KGBIGCOUNTRY's Avatar
3rd Gen / Site Mod
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
Okie, get a larger trans cooler and that should help you.
__________________
RamForum.com Moderator
Its Tweaked & Twisted
Crazy Spartan on a 112lsa Thumping It, PWR Heads Opening It Up, Coated Pacesetters Doing The Rest, Tuned by Spooldu with DSP
Powed and Tuned by King Motorsports
KGBIGCOUNTRY is offline   Reply With Quote
Old 01-30-2012, 10:16 PM   #9 (permalink)
Ram Year: 2000
Engine: magnum, 5.9
Default
I have a 15kGVW cooler, deep sump pan, and a shift kit. The "warm surges" come from leaving stop signs/lights in summer traffic with the air on.
Gears help eliminate the extra demand put on the TC as it strains to pull my truck from a dead stop, especially with a load of wood.
Sorry for the "post jack" Wermbang.
__________________
Old 01-30-2012, 10:25 PM   #10 (permalink)
wermbang's Avatar
Site Administrator
Default
nope your good, more tranny info in here the better
__________________
Reply
Bookmarks
Tags
replacing transmission, tranny problems 2nd gen, transmission failure
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Transmission woes MikesRammin Engine & Performance 6 02-17-2012 01:41 AM
Transmission problem jakeduece Engine & Performance 8 01-13-2012 03:55 PM
Transmission issue!! Help please! muzik36 Tech Info 7 11-23-2011 03:23 PM
Transmission Problems varam Engine & Performance 6 06-27-2011 04:14 PM
After 5 days of work and alot of work kicker417 Lifted 20 08-02-2010 08:14 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
