How can I wire a push button to be able to test crank the engine from under the hood?
I'm good with electronic, so the question is mostly:
1) What minimum do I need to get the starter to engage, the spark plugs to fire and the ECU to let the engine run?
2) Where are the best points to attach the wires? (I'd just have it attached if I'm working on the engine)
Anybody make a ready-made versions that aren't $$$$$$$?
Sent from my SM-G950U using Tapatalk
