wmkfisher
- Jul 29, 2016
- 1
- 0
- 2002
- 4.7 magnum
So I have an 02 1500 4.7, with a code of p0305 cylinder 5 misfire, I have oil on the threads down to the tip forming a drop and the SOB is just billowing smoke on start, white with a blue tint, not loosing coolant and the oil doesn't look contaminated, so is it the right direction to just go with the valve/ stem seals, and it sounds like there is a an air leak somewhere due to the awful roar that is produced when I even slightly push the throttle, doesn't have it at idle though.
thanks in advance will most likely post pictures of the spark plug sometime tonight once I get back at it.
